Up to 20% off select tools
Dewalt DCD778 Forward/Reverse Switch Replacement
Views: 3.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
34
Past 30 Days:
143
All Time:
3,206
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
This guide will teach you how to properly replace your forward/reverse switch for the Dewalt DCD778.
    1. Dewalt DCD778 Forward/Reverse Switch  Replacement, Battery: step 1, image 1 of 1
      • Grab the drill in one hand and cup the battery (located at the bottom of the drill) with the other hand.
      Ask FixBot
    2. Dewalt DCD778 Forward/Reverse Switch  Replacement: step 2, image 1 of 1
      • Use your other hand to push down on the yellow button on the battery.
      Ask FixBot
    3. Dewalt DCD778 Forward/Reverse Switch  Replacement: step 3, image 1 of 1
      • Pull the battery in a horizontal direction away from the drill.
      Ask FixBot
    1. Dewalt DCD778 Forward/Reverse Switch  Replacement, Forward/Reverse Switch: step 4, image 1 of 1
      • Remove the eight 16 mm, Torx Security #15 screws.
      Ask FixBot
    2. Dewalt DCD778 Forward/Reverse Switch  Replacement: step 5, image 1 of 1
      • Lay the drill on its side and gently lift the top half off it.
      Ask FixBot
    3. Dewalt DCD778 Forward/Reverse Switch  Replacement: step 6, image 1 of 1
      • Remove the drill mechanism from the shell.
      Ask FixBot
    4. Dewalt DCD778 Forward/Reverse Switch  Replacement: step 7, image 1 of 1
      • Disconnect the forward/reverse switch from the trigger by pulling the mechanism out and leaving the switch in the frame.
      • To replace just pull the switch out and put the new one in the opening.
      Ask FixBot
Author
with
Brittany
705 Reputation
5 Guides authored
1 Guide Comment
Just pull it out? It has wires going into it!
joe roe - Reply Share
Past 24 Hours: 3
Past 7 Days: 34
Past 30 Days: 143
All Time: 3,206
