Determining Wire Connectivity for Skullcandy Lowrider
  1. Determining Wire Connectivity for Skullcandy Lowrider, Checking to See if the Wire is Still Connected to the Ear-Cup: step 1, image 1 of 2 Determining Wire Connectivity for Skullcandy Lowrider, Checking to See if the Wire is Still Connected to the Ear-Cup: step 1, image 2 of 2
    • Pull the edge of the pad where it meets the plastic of the ear-cup to separate the padding from the ear pad.
    Ask FixBot
  2. Determining Wire Connectivity for Skullcandy Lowrider: step 2, image 1 of 2 Determining Wire Connectivity for Skullcandy Lowrider: step 2, image 2 of 2
    • Use the small Phillips screwdriver to remove three 8mm screws on the surface of the earphones.
    Ask FixBot
  3. Determining Wire Connectivity for Skullcandy Lowrider: step 3, image 1 of 1
    • Now that the screws have been removed, use your hands to separate the plate from the rest of headphone.
    • Here, you will be able to check the connectivity of your auxiliary cord to its port in an appropriate ear-cup.
    Ask FixBot
  4. Determining Wire Connectivity for Skullcandy Lowrider: step 4, image 1 of 1
    • Now that you have removed the plate you can check the wiring connectivity. If the wire is not connected to any sources inside the ear-cup, as shown in the image to the right, then this is the reason that your headphone(s) are not working.
    • Now that you have verified your problem, refer to the guide Skullcandy Lowrider Wiring Repair to fix the loose wiring.
    Ask FixBot
Ryley
273 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 38
All Time: 1,454
