Up to 20% off select tools
This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Detectometer Assembly Guide
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
99
All Time:
649
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 40 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
This guide shows you how to assemble a detectometer using an Arduino Mega board, an energy shield, a detectometer shield, a screen, and a Bluetooth module.
    1. Detectometer Assembly Guide, Detectometer Assembly Guide: step 1, image 1 of 3 Detectometer Assembly Guide, Detectometer Assembly Guide: step 1, image 2 of 3 Detectometer Assembly Guide, Detectometer Assembly Guide: step 1, image 3 of 3
      • gather all necessary equipment
      • 1 Arduino Mega
      • 1 detectometer shield
      • 1 energy shield + the battery
      Ask FixBot
    2. Detectometer Assembly Guide: step 2, image 1 of 3 Detectometer Assembly Guide: step 2, image 2 of 3 Detectometer Assembly Guide: step 2, image 3 of 3
      • 1 screen
      • 1 Bluetooth module along with its small cable
      • 1 MicroSD card
      Ask FixBot
    3. Detectometer Assembly Guide: step 3, image 1 of 3 Detectometer Assembly Guide: step 3, image 2 of 3 Detectometer Assembly Guide: step 3, image 3 of 3
      • 5 connectors
      • A case
      • the screws
      Ask FixBot
    4. Detectometer Assembly Guide: step 4, image 1 of 3 Detectometer Assembly Guide: step 4, image 2 of 3 Detectometer Assembly Guide: step 4, image 3 of 3
      • Start by trimming the energy shield card using flush cutters flush with the blue connector
      • Cut the connector leads to leave approximately 7 mm
      Ask FixBot
    5. Detectometer Assembly Guide: step 5, image 1 of 3 Detectometer Assembly Guide: step 5, image 2 of 3 Detectometer Assembly Guide: step 5, image 3 of 3
      • Insert the connectors into the Arduino, and stack them as shown in the first image; there should be no gap between them.
      • Connect the battery to the shield and insert it into the Arduino.
      • Once the operation is complete, check the alignment; the connectors should be at approximately the same level.
      Ask FixBot
    6. Detectometer Assembly Guide: step 6, image 1 of 2 Detectometer Assembly Guide: step 6, image 2 of 2
      • Prepare the Detectomètre shield and connect the Bluetooth module to the input labeled as such
      • Insert the MicroSD card into the reader
      Ask FixBot
    7. Detectometer Assembly Guide: step 7, image 1 of 2 Detectometer Assembly Guide: step 7, image 2 of 2
      • Be sure to route the base battery wires between the two connectors as shown in the second photo
      • Now insert the detectometer shield onto the base (arduino + energy shield + connectors)
      Ask FixBot
    8. Detectometer Assembly Guide: step 8, image 1 of 1
      • Insert the screen onto the yellow connectors
      • All that remains is to assemble the box
      Ask FixBot
    9. Detectometer Assembly Guide: step 9, image 1 of 2 Detectometer Assembly Guide: step 9, image 2 of 2
      • Install the "sensor inputs" faceplate and connect the cables to the correct connectors
      • Route the 2 sensor cables on either side of the detector shield and position the faceplate as shown in the second photo
      Ask FixBot
    10. Detectometer Assembly Guide: step 10, image 1 of 1
      • Once the box is assembled, position the white spacers + washer and screw them in
      • Don't forget the small washer! Otherwise, the box might break
      Ask FixBot
    11. Detectometer Assembly Guide: step 11, image 1 of 1
      • Congratulations! You have just assembled the detectometer!
      Ask FixBot
Author
with
julienrat
166 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 99
All Time: 649
