Detach the Behringer Eurolive B212D Electronics Box
    1. Detach the Behringer Eurolive B212D Electronics Box, Electronics Box: step 1, image 1 of 1
      • CAUTION: Unplug your speaker from the power outlet.
      • Remove the 8 Phillips screws from the back of the speaker.
      Ask FixBot
    2. Detach the Behringer Eurolive B212D Electronics Box: step 2, image 1 of 1
      • Carefully remove the back panel, lifting out the metal electronics-box with it.
      • To avoid damaging your speaker, remove slowly, as there is still a wire attached from the electronics box to the speaker.
      Ask FixBot
    1. Detach the Behringer Eurolive B212D Electronics Box, Electronics Box: step 3, image 1 of 3 Detach the Behringer Eurolive B212D Electronics Box, Electronics Box: step 3, image 2 of 3 Detach the Behringer Eurolive B212D Electronics Box, Electronics Box: step 3, image 3 of 3
      • There are two silver, 6 mm-long machine screws with two 1/8" inner-diameter washers on the exterior of the metal electronics box; remove these first using a #2 philips screwdriver.
      • There are five of the same type of machine screw (silver, 6 mm-long) remaining around the metal electronics box's exterior; remove these as well.
      • You should have removed a total of 7 machine screws and 2 washers.
      • The reason for removing the two screws with the two washers first (or replacing them last when reassembling) is that their holes are actually slots. They are designed as slots to accommodate slop in the assembly, and if unscrewed out of order, you may have difficulty while removing - or possibly even damage - the other five screws.
      Ask FixBot
    2. Detach the Behringer Eurolive B212D Electronics Box: step 4, image 1 of 1
      • Remove the portion of the metal housing that you freed with the 7 screws in the previous step.
      Ask FixBot
    3. Detach the Behringer Eurolive B212D Electronics Box: step 5, image 1 of 3 Detach the Behringer Eurolive B212D Electronics Box: step 5, image 2 of 3 Detach the Behringer Eurolive B212D Electronics Box: step 5, image 3 of 3
      • Inside the metal electronics box housing is a white clip attached to a small PCB; remove this.
      • The white clip in this image has been glued, indicating that the manufacturer may not expect the end user to remove this clip; it is difficult to proceed with the disassembling without doing so, however, because the rest of the speaker does not provide a sufficient surface on which to work.
      • Snake the clip head through the hole in the metal electronics box casing.
      Ask FixBot
4 other people completed this guide.
Troy W. Weber
1,506 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 26
All Time: 3,160
