Up to 20% off select tools
Desktop PC Motherboard Replacement
Views: 39K
View statistics:
Past 24 Hours:
12
Past 7 Days:
58
Past 30 Days:
305
All Time:
38,788
Comments: 13
7 comments on steps, 6 guide comments.
Go to guide comments
Completed: 114
114 people have marked this guide "completed." Will you be next?
Favorites: 15
15 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 30 minutes
Difficulty: Moderate
Missing Steps
Oops! This guide is currently missing one or more important steps.
Tools
Introduction
Go to step 1 ↓
The motherboard is the main body of a computer. Over time, computer components degrade and may need to be replaced. Replacing the motherboard can help make a computer run more quickly, smoothly and without errors.
    1. Desktop PC Motherboard Replacement, Left Panel: step 1, image 1 of 1
      • Unplug the computer from the power supply before any maintenance or disassembly.
      • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
      • These screws can usually be removed by hand.
      • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
      Ask FixBot
    2. Desktop PC Motherboard Replacement: step 2, image 1 of 2 Desktop PC Motherboard Replacement: step 2, image 2 of 2
      • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
      • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
      Ask FixBot
    1. Desktop PC Motherboard Replacement, Right Panel: step 3, image 1 of 1
      • Remove two Phillips #2 head 5mm screws from the back side of the computer case.
      Ask FixBot
    2. Desktop PC Motherboard Replacement: step 4, image 1 of 2 Desktop PC Motherboard Replacement: step 4, image 2 of 2
      Ask FixBot
    1. Desktop PC Motherboard Replacement, Graphics Card: step 5, image 1 of 1
      • Remove the Phillips #2 head, 5mm screw holding the graphics card in place.
      • Make sure that you have grounded yourself so that upon removal of the graphics card you do not accidentally shock the circuit board and damage it.
      Ask FixBot
    2. Desktop PC Motherboard Replacement: step 6, image 1 of 2 Desktop PC Motherboard Replacement: step 6, image 2 of 2
      • Press the latch on the side of the connector area to unlock the graphics card, and carefully slide the graphics card out from its slot in the computer.
      • A good technique is to lay the computer onto it side, push the latch down and lift the graphics card out.
      Ask FixBot
    1. Desktop PC Motherboard Replacement, Hard Drive: step 7, image 1 of 1
      • Remove two Phillips #2 head 5mm screws holding the hard drive in place.
      Ask FixBot
    2. Desktop PC Motherboard Replacement: step 8, image 1 of 1
      • Remove two Phillips #2 head 5mm screws holding in the other side of the hard drive.
      Ask FixBot
    3. Desktop PC Motherboard Replacement: step 9, image 1 of 1
      • Slide the hard drive out from the metal casing.
      Ask FixBot
    4. Desktop PC Motherboard Replacement: step 10, image 1 of 1
      • Remove the cables from the back of the hard drive.
      Ask FixBot
    1. Desktop PC Motherboard Replacement, Motherboard: step 11, image 1 of 2 Desktop PC Motherboard Replacement, Motherboard: step 11, image 2 of 2
      • Begin to disconnect all cables from the motherboard. Many of the cables will have clips that need to be undone before you can remove them from the motherboard.
      Ask FixBot
    2. Desktop PC Motherboard Replacement: step 12, image 1 of 1
      • Remove nine Phillips #2 head 5mm screws from the motherboard. Be sure to have your computer on its side, so that once the screws are out nothing falls and gets damaged.
      Ask FixBot
    3. Desktop PC Motherboard Replacement: step 13, image 1 of 1
      • Double check and make sure all wires and screws have been removed, then carefully remove the motherboard from the computer case.
      Ask FixBot
114 other people completed this guide.
Author
with
David Lennon
10,219 Reputation
10 Guides authored
Cal Poly, Team 4-5, Maness Spring 2015 Member of Cal Poly, Team 4-5, Maness Spring 2015
CPSU-MANESS-S15S4G5
4 Members
132 Guides authored
6 Guide Comments
If you aim to replace just the motherboard, I don’t think removing the hard drive from the case should be neccessary. The point of removing SATA cable from the motherboard still stands.
Ingmārs Zaicevs - Reply Share
Generally a good article for a beginner. Very thorough. I personally do not remove the hard drives or cpu fans as it makes it both faster and easier to hold. Disconnect all the cables and graphics card then unscrew the motherboard screws and you are good to go!
Scott Sinclair - Reply Share
such great info thanks for sharing with us.great blog
jade kelly - Reply Share
hey my pc turn on but it doesn't show on screen.
Thapelo - Reply Share
Hi, first thing I would check is video output default settings, so if you have the monitor connected to a dedicated/discreet graphics card try connecting the video cable to the mobo integrated one or viceversa. Otherwise, the fix could be as simple as replacing the BIOS battery (if the motherboard you are using as replacement is an old one) but could also be a hardware failure/compatibility issue, or a missing power cable (do you hear any beep during power-on self-test?), knowing the PC specs would help identify the problem.
Simone - Reply Share
Past 24 Hours: 12
Past 7 Days: 58
Past 30 Days: 305
All Time: 38,788
