DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
5
Past 7 Days:
26
Past 30 Days:
106
All Time:
1,319
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Introduction
Go to step 1 ↓
Is your input jack broken in your chromatic tuner? Instead of buying a new one you can just buy the input part itself and replace it. This method works for similar tuners but this guide is specifically for the DeltaLab CT-40 Chromatic Tuner.
Tools
    1. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement, Input Jack Port: step 1, image 1 of 2 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement, Input Jack Port: step 1, image 2 of 2
      • First, open the metal stand to access the screws without damaging the body.
      Ask FixBot
    2. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: step 2, image 1 of 2 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: step 2, image 2 of 2
      • Remove the 3 outer 1.2 mm Phillips #1 screws using a small head screwdriver.
      Ask FixBot
    3. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: step 3, image 1 of 2 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: step 3, image 2 of 2
      • Remove the back casing to reveal the inner circuitry.
      Ask FixBot
    4. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: step 4, image 1 of 1
      • Locate the different parts of your tuner, finding the broken input jack port.
      Ask FixBot
    5. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: step 5, image 1 of 2 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: step 5, image 2 of 2
      • Snip the wires attached to the input jack port using the wire cutter as close to the input jack port as possible.
      Ask FixBot
    6. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: step 6, image 1 of 2 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: step 6, image 2 of 2
      • Take your new input jack port and solder the wires to the corresponding connection areas on the new port.
      • Learn how to solder (here).
      Ask FixBot
    7. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: step 7, image 1 of 2 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: step 7, image 2 of 2
      • Fold the wires back and put the new input port into the slot where it belongs on the tuner.
      Ask FixBot
    8. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: step 8, image 1 of 3 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: step 8, image 2 of 3 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: step 8, image 3 of 3
      • Replace the casing and 3 1.2 mm Phillips #1 screws using the screwdriver.
      Ask FixBot
Finish Line
Theodore Tan
137 Reputation
1 Guide authored
Cal Poly, Team 23-4, Green Winter 2015 Member of Cal Poly, Team 23-4, Green Winter 2015
CPSU-GREEN-W15S23G4
7 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 106
All Time: 1,319
