Dell inspiron 15 5502 Memory modules Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
81
All Time:
1,118
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Community-Contributed Guide
Grammar Police
Embrace your inner English teacher and help improve this guide's grammar!
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
      • Save and close all open files and exit all open applications.
      • Shut down your computer. Click Start > Shut down.
      • Disconnect your computer and all attached devices from their electrical outlets.
      • Disconnect all attached network devices and peripherals, such as keyboard, mouse, and monitor from your computer.
      Ask FixBot
    1. Dell inspiron 15 5502 Memory modules Replacement, Screws: step 2, image 1 of 1
      • In the back there are 9 screws.
      • (captive) M2x7.5
      • M2x4
      • Unscrew these and store in a safe place. (eg: nescafe cup, container )
      Ask FixBot
    2. Dell inspiron 15 5502 Memory modules Replacement, Getting the base cover out: step 3, image 1 of 1
      • Using a plastic scribe, pry the base cover starting from the recess at the display hinge and work your way around the sides to remove the base cover.
      Ask FixBot
      • Lift the base cover off the palm-rest and keyboard assembly.
      Ask FixBot
    3. Dell inspiron 15 5502 Memory modules Replacement, Battery disconecting: step 5, image 1 of 2 Dell inspiron 15 5502 Memory modules Replacement, Battery disconecting: step 5, image 2 of 2
      • The sticker and the cable connector(below the sticker)
      • Peel the tape and disconnect the battery cable from the system board.
      Ask FixBot
    4. Dell inspiron 15 5502 Memory modules Replacement, Drain the power: step 6, image 1 of 1
      • Press and hold the power button for five seconds to ground the computer and drain the flea power.
      Ask FixBot
    1. Dell inspiron 15 5502 Memory modules Replacement, Lift the mylar: step 7, image 1 of 3 Dell inspiron 15 5502 Memory modules Replacement, Lift the mylar: step 7, image 2 of 3 Dell inspiron 15 5502 Memory modules Replacement, Lift the mylar: step 7, image 3 of 3
      • Where I am talking about.
      • Lift the mylar to uncover the memory module.
      • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module slot until the memory module pops up.
      Ask FixBot
    2. Dell inspiron 15 5502 Memory modules Replacement, Removing: step 8, image 1 of 1
      • Remove the memory module from the memory-module slot.
      Ask FixBot
      • Store the Ram sticks safely in an anti-static bag.
      Ask FixBot
Finish Line
Kind-hearted, spirited Man
1,079 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 81
All Time: 1,118
