Up to 20% off select tools
Dell XPS M170 MXG051 Memory Module Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
10
Past 30 Days:
49
All Time:
515
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 6 - 15 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
How to replace the memory modules of a Dell XPS M170 MXG051.
    1. Dell XPS M170 MXG051 Memory Module Replacement, Dell XPS M170 MXG051 Battery Removal: step 1, image 1 of 1
      • Turn off your computer. Then, disconnect your computer and all attached devices from their electrical outlets.
      • Close the display and turn the computer upside down on a flat work surface.
      • Slide the battery-bay latch release on the bottom of the computer and remove the battery from the bay.
      Ask FixBot
    1. Dell XPS M170 MXG051 Memory Module Replacement, Remove Memory Module Cover: step 2, image 1 of 1
      • Loosen the two captive screws from the memory module cover, and remove the cover.
      Ask FixBot
    2. Dell XPS M170 MXG051 Memory Module Replacement: step 3, image 1 of 1
      • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
      • Remove the module(s) from the connector at a 45 - degree angle.
      Ask FixBot
    3. Dell XPS M170 MXG051 Memory Module Replacement, Install New Memory: step 4, image 1 of 1
      • Align the notch in the new memory module's edge connector with the tab in the connector slot.
      • Slide the module firmly into the slot at a 45 - degree angle, and press the the module down (so that it is horizontal. If you do not feel the memory module click into place after you press it down, remove the module and reinstall it.
      Ask FixBot
    4. Dell XPS M170 MXG051 Memory Module Replacement: step 5, image 1 of 1
      • Replace the memory cover and tighten the captive screws.
      Ask FixBot
Finish Line
Author
with
Johnathan Hammond
46,425 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 49
All Time: 515
