Dell XPS M1530 Wireless Card Replacement
    1. Dell XPS M1530 Wireless Card Replacement, Battery: step 1, image 1 of 1
      • Turn the computer upside down with the battery facing you.
      • Turn the computer off and disconnect the charging cable from the computer.
      • Failure to unplug the charging cable may result in electric shock.
      Ask FixBot
    2. Dell XPS M1530 Wireless Card Replacement: step 2, image 1 of 1
      • Push the switch as far to the right as possible to unlock the battery.
      Ask FixBot
    3. Dell XPS M1530 Wireless Card Replacement: step 3, image 1 of 2 Dell XPS M1530 Wireless Card Replacement: step 3, image 2 of 2
      • Remove the battery using two hands and pull it away from the computer.
      Ask FixBot
    1. Dell XPS M1530 Wireless Card Replacement, Wireless Card: step 4, image 1 of 1
      • Unscrew the two 4.7mm Phillips #1 screws on the bottom panel of the laptop.
      • Two 4.7mm Philips #1 screws
      Ask FixBot
    2. Dell XPS M1530 Wireless Card Replacement: step 5, image 1 of 2 Dell XPS M1530 Wireless Card Replacement: step 5, image 2 of 2
      • Lift the panel up from the indented area.
      • This indent should provide enough grip to remove the panel with ease.
      Ask FixBot
    3. Dell XPS M1530 Wireless Card Replacement: step 6, image 1 of 1
      • Remove the single 3.9mm Phillips #1 screw in the upper right corner of the wireless card.
      • One 3.9mm Phillips #1 screw
      Ask FixBot
    4. Dell XPS M1530 Wireless Card Replacement: step 7, image 1 of 1
      • Lift the card out at an angle and carefully remove it.
      Ask FixBot
    5. Dell XPS M1530 Wireless Card Replacement: step 8, image 1 of 2 Dell XPS M1530 Wireless Card Replacement: step 8, image 2 of 2
      • Use a spudger to carefully disconnect the antenna cables from the card by prying them straight up off the board.
      • It's best to use an ESD-safe tool, such as a nylon spudger, rather than the metal spudger shown in the photo.
      • Note the order of colors for the antenna cables indicated on the card.
      Ask FixBot
Jase Sasaki
721 Reputation
5 Guides authored
Cal Poly, Team 18-4, Maness Winter 2015 Member of Cal Poly, Team 18-4, Maness Winter 2015
CPSU-MANESS-W15S18G4
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 95
All Time: 2,306
