Dell XPS M1530 Battery Replacement
Views: 2K
View statistics:
Past 24 Hours:
Past 7 Days:
24
Past 30 Days:
94
All Time:
1,990
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
You have already determined that your laptop charger is functional, but your computer still does not turn on. In addition, you have also tested that your laptop does not turn on when plugged in. If this is the case then the battery is most likely dead/drained and you must replace it.
    1. Dell XPS M1530 Battery Replacement, Battery: step 1, image 1 of 1
      • Turn the computer upside down with the battery facing you.
      • Turn the computer off and disconnect the charging cable from the computer.
      • Failure to unplug the charging cable may result in electric shock.
      Ask FixBot
    2. Dell XPS M1530 Battery Replacement: step 2, image 1 of 1
      • Push the switch as far to the right as possible to unlock the battery.
      Ask FixBot
    3. Dell XPS M1530 Battery Replacement: step 3, image 1 of 2 Dell XPS M1530 Battery Replacement: step 3, image 2 of 2
      • Remove the battery using two hands and pull it away from the computer.
      Ask FixBot
Tyler Scholz
479 Reputation
3 Guides authored
Cal Poly, Team 18-4, Maness Winter 2015 Member of Cal Poly, Team 18-4, Maness Winter 2015
CPSU-MANESS-W15S18G4
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 24
Past 30 Days: 94
All Time: 1,990
