Up to 20% off select tools
Dell XPS M140 Screen Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
24
Past 30 Days:
81
All Time:
855
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 25 - 45 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will help users properly and safely disassemble their Dell XPS M140 laptop to reach the LCD (Liquid Crystal Display). Users will be able to see which exact step-wise components they will have to remove in order to gain access to the LCD screen.
    1. Dell XPS M140 Screen Replacement, Battery: step 1, image 1 of 1
      • Turn over the laptop.
      Ask FixBot
    2. Dell XPS M140 Screen Replacement: step 2, image 1 of 3 Dell XPS M140 Screen Replacement: step 2, image 2 of 3 Dell XPS M140 Screen Replacement: step 2, image 3 of 3
      • Open the slide lock and pull out the battery.
      Ask FixBot
    1. Dell XPS M140 Screen Replacement, Screen: step 3, image 1 of 3 Dell XPS M140 Screen Replacement, Screen: step 3, image 2 of 3 Dell XPS M140 Screen Replacement, Screen: step 3, image 3 of 3
      • The plastic casing around the screen has a gray rubber circle, lining the perimeter of the casing.
      • Remove the casing by peeling them off. This will expose the screws underneath.
      Ask FixBot
    2. Dell XPS M140 Screen Replacement: step 4, image 1 of 1
      • Unscrew the screws on the casing that you just exposed.
      Ask FixBot
    3. Dell XPS M140 Screen Replacement: step 5, image 1 of 3 Dell XPS M140 Screen Replacement: step 5, image 2 of 3 Dell XPS M140 Screen Replacement: step 5, image 3 of 3
      • With care, pop off the plastic clips sourrounding the casing.
      • Run your hand, or a tool, around the perimeter, to remove the casing.
      Ask FixBot
    4. Dell XPS M140 Screen Replacement: step 6, image 1 of 3 Dell XPS M140 Screen Replacement: step 6, image 2 of 3 Dell XPS M140 Screen Replacement: step 6, image 3 of 3
      • Once the casing is removed, more screws should be exposed.
      • Remove every screw.
      Ask FixBot
    5. Dell XPS M140 Screen Replacement: step 7, image 1 of 3 Dell XPS M140 Screen Replacement: step 7, image 2 of 3 Dell XPS M140 Screen Replacement: step 7, image 3 of 3
      • Once all of the screws are removed, the screen should be loose.
      • Gently pick it up and place it face down onto the keyboard.
      Ask FixBot
    6. Dell XPS M140 Screen Replacement: step 8, image 1 of 3 Dell XPS M140 Screen Replacement: step 8, image 2 of 3 Dell XPS M140 Screen Replacement: step 8, image 3 of 3
      • There should be two connections.
      • One with a blue looking handle, and one with clips.
      • To remove the connection with the clips, squeeze the two clips together and pull the ribbon cable.
      • To remove the connection with the blue handle, gently pull on the blue handle, it should come right off.
      Ask FixBot
Author
with
Travis Morazzini
207 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 81
All Time: 855
