Dell XPS M1330 RAM Replacement
      • NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
      • NOTICE: If there is a memory module in DIMM 2, remove it prior to removing the memory module from DIMM 1. Failure to do so could result in damage to both memory modules
      • Turn the computer over and loosen the three captive screws and the M2.5 x 5-mm screw. Remove the module cover.
      • Remove the module from the connector.
      Ask FixBot
      • Align the notch in the module edge connector with the tab in the connector slot.
      • Slide the module firmly into the slot at a 45-degree angle, and rotate the module down until it clicks into place. If you do not feel the click, remove the module and reinstall it.
      • NOTE: If the memory module is not installed properly, the computer may not boot. No error message indicates this failure.
      • NOTICE: If the cover is difficult to close, remove the module and reinstall it. Forcing the cover to close may damage your computer.
      • Replace the module cover.
      • Insert the battery into the battery bay, or connect the AC adapter to your computer and an electrical outlet.
      • Turn on the computer.
      Ask FixBot
Amia Frazier
887 Reputation
7 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 59
All Time: 430
