Dell XPS M1330 CPU Replacement
    1. Dell XPS M1330 CPU Replacement, Battery: step 1, image 1 of 1
      • Flip the laptop on its back, so that the underside is facing up.
      Ask FixBot
    2. Dell XPS M1330 CPU Replacement: step 2, image 1 of 1
      • Push and hold the slide button to the left and unlock the mechanism.
      Ask FixBot
    3. Dell XPS M1330 CPU Replacement: step 3, image 1 of 2 Dell XPS M1330 CPU Replacement: step 3, image 2 of 2
      • Lift the computer up and slowly pull the battery straight out from the device.
      Ask FixBot
    1. Dell XPS M1330 CPU Replacement, Fan: step 4, image 1 of 2 Dell XPS M1330 CPU Replacement, Fan: step 4, image 2 of 2
      • Remove the four 5.0mm screws with a Phillips #1 screwdriver.
      • Remove the one external 5.0mm screw with a Phillips #1 screwdriver.
      • Remove the fan cover.
      Ask FixBot
    2. Dell XPS M1330 CPU Replacement: step 5, image 1 of 1
      • Remove the four 0.1mm screws using the Phillips #1 screwdriver.
      • Remove the one thicker 0.1 mm screw using the Phillips #1 screwdriver.
      Ask FixBot
    3. Dell XPS M1330 CPU Replacement: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Be sure to carefully remove the wires as they are fragile and can rip easily.
      • Remove the wire bay near the fan.
      • Use the long nosed tweezers to carefully handle the white plastic piece that holds the wires together.
      • Gently pull upward while moving your hand side to side so the plastic holder will detach.
      Ask FixBot
    4. Dell XPS M1330 CPU Replacement: step 7, image 1 of 1
      • Gently remove the fan and its attachments from the bay.
      Ask FixBot
    1. Dell XPS M1330 CPU Replacement, CPU: step 8, image 1 of 1
      • Using the flathead screwdriver, turn the one screw counterclockwise to loosen the CPU, but do not remove the screw.
      Ask FixBot
    2. Dell XPS M1330 CPU Replacement: step 9, image 1 of 1
      • Using the iFixit opening tool, prop up the CPU.
      Ask FixBot
    3. Dell XPS M1330 CPU Replacement: step 10, image 1 of 1
      • Carefully lift the CPU away from its housing.
      Ask FixBot
Kai Kapossy
739 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 23
Past 30 Days: 72
All Time: 1,289
