Dell XPS M1210 Fan Replacement
    1. Dell XPS M1210 Fan Replacement, Fan: step 1, image 1 of 3 Dell XPS M1210 Fan Replacement, Fan: step 1, image 2 of 3 Dell XPS M1210 Fan Replacement, Fan: step 1, image 3 of 3
      • Before opening up your laptop make sure it is completely turned off and is not connected to the charger.
      • To prevent any damage to the system ,remove the main battery.
      • Turn the computer upside down and loosen the captive screw on the communications card cover.
      • Disconnect any antenna cables that are attached to the Mini-cards.
      Ask FixBot
    2. Dell XPS M1210 Fan Replacement: step 2, image 1 of 3 Dell XPS M1210 Fan Replacement: step 2, image 2 of 3 Dell XPS M1210 Fan Replacement: step 2, image 3 of 3
      • Open the display 180 degrees.
      • Insert a plastic scribe or a flat head screwdriver into the indent of the hinge cover on the right. Pry open the hinge cover.
      • Be gentle when prying open the hinge cover. Wiggle the cover left and right slowly lifting it up.
      Ask FixBot
    3. Dell XPS M1210 Fan Replacement: step 3, image 1 of 3 Dell XPS M1210 Fan Replacement: step 3, image 2 of 3 Dell XPS M1210 Fan Replacement: step 3, image 3 of 3
      • Remove the three Philips head screws at the top of the keyboard.
      • Lift the keyboard slightly up to disconnect the keyboard cable from the system board.
      • There will be a keyboard-connector pull-tab that will separate the keyboard from the laptop.
      Ask FixBot
    4. Dell XPS M1210 Fan Replacement: step 4, image 1 of 3 Dell XPS M1210 Fan Replacement: step 4, image 2 of 3 Dell XPS M1210 Fan Replacement: step 4, image 3 of 3
      • Use the pull-tab to disconnect the display cable from the system board.
      • Disconnect the display cable and the antenna cables from their cable channels.
      • Remove the four screws that connect the display to the computer base. There should be two on the bottom and two on the back of the computer labeled "D".
      • The display should then be disconnected from the rest of the laptop.
      Ask FixBot
    5. Dell XPS M1210 Fan Replacement: step 5, image 1 of 3 Dell XPS M1210 Fan Replacement: step 5, image 2 of 3 Dell XPS M1210 Fan Replacement: step 5, image 3 of 3
      • To remove the palm rest there will be seven screws labeled "P" that need to be removed.
      • Disconnect the coin-cell battery cable from the system board.
      • Then disconnect the touch-pad connector from the system board.
      • Turn the computer upside down. Loosen the captive screw, and remove the four screws from the bottom of the computer.
      • Lift the palm rest from the back of the computer to separate it.
      Ask FixBot
    6. Dell XPS M1210 Fan Replacement: step 6, image 1 of 3 Dell XPS M1210 Fan Replacement: step 6, image 2 of 3 Dell XPS M1210 Fan Replacement: step 6, image 3 of 3
      • Remove the screw from the fan, and then disconnect the fan cable from the system board.
      Ask FixBot
To reassemble your device, secure the fan with the 4 screws, and reinstall the keyboard and hinge cover in reverse order of the above instructions.
Dave
229 Reputation
2 Guides authored
Penn State, Team 1-100, Kaschak Winter 2015 Member of Penn State, Team 1-100, Kaschak Winter 2015
PSU-KASCHAK-W15S1G100
4 Members
24 Guides authored
2 Guide Comments
Thanks for the explanation , was simply splendid.
Can you please share the part number of the Fan ? is it DELL XPS M1210 MCF-J10BM05 ?
tvshprakash - Reply Share
Why do we need to remove the screen?
Louis Cox - Reply Share
Past 24 Hours: 7
Past 7 Days: 26
Past 30 Days: 105
All Time: 2,088
