Dell XPS 9720 Fan Replacement
    1. Dell XPS 9720 Fan Replacement, Remove back cover: step 1, image 1 of 1
      • Unscrew 8 T5 screws. Use an opening tool to pop open the plastic tabs holding the aluminum and carbon fiber shells together.
      Ask FixBot
    2. Dell XPS 9720 Fan Replacement, Disconnect battery: step 2, image 1 of 2 Dell XPS 9720 Fan Replacement, Disconnect battery: step 2, image 2 of 2
      • Insert finger into plastic loop and pull firmly away from motherboard.
      Ask FixBot
    3. Dell XPS 9720 Fan Replacement, Remove fan: step 3, image 1 of 2 Dell XPS 9720 Fan Replacement, Remove fan: step 3, image 2 of 2
      • Gently unplug the fan connector.
      • Remove the two PH1 (red) and single PH00 (blue) screws.
      • The fan may now be lifted from the chassis. Reverse these steps to install the new fan.
      Ask FixBot
Sebastien Bolle
350 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 65
All Time: 882
