Dell XPS 7590 SSD Replacement
    1. Dell XPS 7590 SSD Replacement, Flip laptop around: step 1, image 1 of 1
      • Flip your device the other way around
      • Don't be confused that this device is black, its a skin
      Ask FixBot
    2. Dell XPS 7590 SSD Replacement, Remove 10 Torx T5: step 2, image 1 of 3 Dell XPS 7590 SSD Replacement, Remove 10 Torx T5: step 2, image 2 of 3 Dell XPS 7590 SSD Replacement, Remove 10 Torx T5: step 2, image 3 of 3
      • Grab your T5 Torx and identify the 10 torx screws
      • Make sure that this is a T5, to not strip the screws. They can be very difficult to remove
      • Careful there are more screws, do not try to open yet!
      Ask FixBot
    3. Dell XPS 7590 SSD Replacement, Remove Flap Screws: step 3, image 1 of 1
      • Open the flap on the back of the laptop
      • There are two screws that need to be removed, please use a Philips 0 screwdriver
      Ask FixBot
    4. Dell XPS 7590 SSD Replacement, Remove Backplate: step 4, image 1 of 1
      • The backplate might not be easy to open
      • You can use a soft prytool to open the laptop easier
      • Don't insert the tool too deep or you might break the mainboard
      • Now, you should be able to remove the backplate
      Ask FixBot
    5. Dell XPS 7590 SSD Replacement, Unplug Battery: step 5, image 1 of 3 Dell XPS 7590 SSD Replacement, Unplug Battery: step 5, image 2 of 3 Dell XPS 7590 SSD Replacement, Unplug Battery: step 5, image 3 of 3
      • Locate the battery connection to the mainboard
      • Unplug the battery before doing anything else
      • You can use a pry tool to make this easier
      Ask FixBot
    6. Dell XPS 7590 SSD Replacement, Locate and remove SDD: step 6, image 1 of 3 Dell XPS 7590 SSD Replacement, Locate and remove SDD: step 6, image 2 of 3 Dell XPS 7590 SSD Replacement, Locate and remove SDD: step 6, image 3 of 3
      • Locate the SDD on the mainboard
      • Use a Philips 0 to remove the screw of the SDD
      • Slide the SSD out of its socket.
      • Try not to lift the SSD any more than necessary
      • During reassembly, make sure the slot in the SSD lines up with the slot in its socket. Do not touch the gold-colored contacts with your fingers.
      • Reconnect the battery and reassemble
      Ask FixBot
4 other people completed this guide.
Max Lembke
951 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 25
Past 30 Days: 95
All Time: 4,531
