Dell XPS 720 H2C Sound Card Replacement
  1. Dell XPS 720 H2C Sound Card Replacement, Removing Dell XPS 720 H2C Cover Panel: step 1, image 1 of 2 Dell XPS 720 H2C Sound Card Replacement, Removing Dell XPS 720 H2C Cover Panel: step 1, image 2 of 2
    • Remove the cover panel on the side of the computer by pulling out the latch on the back panel and pulling the panel downwards towards the ground.
    Ask FixBot
  2. Dell XPS 720 H2C Sound Card Replacement, Sound Card: step 2, image 1 of 2 Dell XPS 720 H2C Sound Card Replacement, Sound Card: step 2, image 2 of 2
    • Before handling the inside of the computer, ensure that all wires are disconnected from the audio ports along the back panel.
    • The sound card is located towards the bottom of the computer, near the righthand side (see red outline).
    Ask FixBot
  3. Dell XPS 720 H2C Sound Card Replacement: step 3, image 1 of 3 Dell XPS 720 H2C Sound Card Replacement: step 3, image 2 of 3 Dell XPS 720 H2C Sound Card Replacement: step 3, image 3 of 3
    • To remove the support below the processor: press down on the latch at the top of the support, then pull the support outwards, towards yourself.
    Ask FixBot
  4. Dell XPS 720 H2C Sound Card Replacement: step 4, image 1 of 1
    • To unplug the wire that connects the sound card to the motherboard: grasp the wire tightly and pull it outwards, towards yourself.
    • The wire may appear to be stuck. Keep increasing your pulling force until the wire unplugs. It will not break.
    Ask FixBot
  5. Dell XPS 720 H2C Sound Card Replacement: step 5, image 1 of 1
    • To release the sound card from the motherboard casing: find the blue tab that is the third from the bottom (fifth from the top), and press down and to the right on the tab.
    Ask FixBot
  6. Dell XPS 720 H2C Sound Card Replacement: step 6, image 1 of 2 Dell XPS 720 H2C Sound Card Replacement: step 6, image 2 of 2
    • To remove the sound card from the motherboard: gently grasp the sound card and pull directly outward, towards yourself.
    • Again, this may appear to be stuck in place. Slightly increase your pulling force until the card releases from the motherboard.
    Ask FixBot
G B
67 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 47
All Time: 1,909
