Dell XPS 720 H2C Memory Modules Replacement
    1. Dell XPS 720 H2C Memory Modules Replacement, Removing Dell XPS 720 H2C Cover Panel: step 1, image 1 of 2 Dell XPS 720 H2C Memory Modules Replacement, Removing Dell XPS 720 H2C Cover Panel: step 1, image 2 of 2
      • Remove the cover panel on the side of the computer by pulling out the latch on the back panel and pulling the panel downwards towards the ground.
      Ask FixBot
    1. Dell XPS 720 H2C Memory Modules Replacement, Memory Modules: step 2, image 1 of 3 Dell XPS 720 H2C Memory Modules Replacement, Memory Modules: step 2, image 2 of 3 Dell XPS 720 H2C Memory Modules Replacement, Memory Modules: step 2, image 3 of 3
      • The memory modules are located directly above the XPS processor and are attached to the motherboard.
      • There are notches securing the memory modules onto the motherboard.
      • Push down and outward on the both notches to release each memory module from the motherboard.
      Ask FixBot
    2. Dell XPS 720 H2C Memory Modules Replacement: step 3, image 1 of 1
      • Carefully remove each memory module from its slot.
      • If you are reseating the memory modules, this is the time to clean them and make sure there isn't any dust build up on the surface.
      Ask FixBot
2 other people completed this guide.
Alexis Cervantes
279 Reputation
2 Guides authored
Cal Poly, Team 4-16, Maness Spring 2013 Member of Cal Poly, Team 4-16, Maness Spring 2013
CPSU-MANESS-S13S4G16
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 26
All Time: 1,609
