Dell XPS 720 H2C Hard Drive Replacement
  1. Dell XPS 720 H2C Hard Drive Replacement, Removing Dell XPS 720 H2C Cover Panel: step 1, image 1 of 2 Dell XPS 720 H2C Hard Drive Replacement, Removing Dell XPS 720 H2C Cover Panel: step 1, image 2 of 2
    • Remove the cover panel on the side of the computer by pulling out the latch on the back panel and pulling the panel downwards towards the ground.
    Ask FixBot
  2. Dell XPS 720 H2C Hard Drive Replacement, Hard Drive: step 2, image 1 of 2 Dell XPS 720 H2C Hard Drive Replacement, Hard Drive: step 2, image 2 of 2
    • The hard drive is located the top-center area of the computer.
    • Carefully disconnect the data and power cables from the hard drive.
    Ask FixBot
  3. Dell XPS 720 H2C Hard Drive Replacement: step 3, image 1 of 1
    • Push the tabs on both sides of the hard drive bracket towards each other and slide the hard drive up and out of the hard drive bay.
    Ask FixBot
  4. Dell XPS 720 H2C Hard Drive Replacement: step 4, image 1 of 2 Dell XPS 720 H2C Hard Drive Replacement: step 4, image 2 of 2
    • Unscrew the four 5mm screws on both sides of the hard drive using the Phillips #1 screwdriver and then remove the hard drive from the case.
    Ask FixBot
2 other people completed this guide.
G B
67 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 32
All Time: 2,070
