Dell XPS 720 H2C Card Fan Replacement
  1. Dell XPS 720 H2C Card Fan Replacement, Removing Dell XPS 720 H2C Cover Panel: step 1, image 1 of 2 Dell XPS 720 H2C Card Fan Replacement, Removing Dell XPS 720 H2C Cover Panel: step 1, image 2 of 2
    • Remove the cover panel on the side of the computer by pulling out the latch on the back panel and pulling the panel downwards towards the ground.
    Ask FixBot
  2. Dell XPS 720 H2C Card Fan Replacement, Card Fan: step 2, image 1 of 2 Dell XPS 720 H2C Card Fan Replacement, Card Fan: step 2, image 2 of 2
    • The card fan is located at the bottom left corner of the computer.
    • Remove the cable connecting the fan to the motherboard.
    • You will have to push a tiny lever on top of the connector and pull the cable to the left at the same time to remove the cable from the motherboard.
    Ask FixBot
  3. Dell XPS 720 H2C Card Fan Replacement: step 3, image 1 of 2 Dell XPS 720 H2C Card Fan Replacement: step 3, image 2 of 2
    • Disconnect the fan from the cage housing by pressing down on the release triggers and pushing them to the right.
    Ask FixBot
  4. Dell XPS 720 H2C Card Fan Replacement: step 4, image 1 of 2 Dell XPS 720 H2C Card Fan Replacement: step 4, image 2 of 2
    • Slide each corner of the fan cage off of the rubber grommets attached to the fan.
    • The rubber grommets may be difficult to remove. You have to squeeze the base of the grommet and pull the cage apart at the same time. The grommets should be pulled apart one at a time.
    Ask FixBot
3 other people completed this guide.
G B
67 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 39
All Time: 2,337
