Dell XPS 18 Touch Control Board Replacement
    1. Dell XPS 18 Touch Control Board Replacement, Back Cover: step 1, image 1 of 1
      • Turn the device on its screen.
      • Remove the ten 4mm screws using a T8 Torx screwdriver.
      Ask FixBot
    2. Dell XPS 18 Touch Control Board Replacement: step 2, image 1 of 1
      • Gently flip out support feet located near the bottom of device.
      Ask FixBot
    3. Dell XPS 18 Touch Control Board Replacement: step 3, image 1 of 1
      • Gently lift the back cover off the device. The back cover should come off easily.
      Ask FixBot
    1. Dell XPS 18 Touch Control Board Replacement, Internal Cover: step 4, image 1 of 1
      • Use the opening tool's angled edge to lift the clasps securing the screen and motherboard cables.
      Ask FixBot
    2. Dell XPS 18 Touch Control Board Replacement: step 5, image 1 of 2 Dell XPS 18 Touch Control Board Replacement: step 5, image 2 of 2
      • Disconnect the screen and copper colored motherboard cables and tuck them under the device to prevent future hassle.
      Ask FixBot
    3. Dell XPS 18 Touch Control Board Replacement: step 6, image 1 of 2 Dell XPS 18 Touch Control Board Replacement: step 6, image 2 of 2
      • Remove the two black 3mm screws from the internal cover with a Phillips 00 screwdriver.
      • Remove the internal cover.
      Ask FixBot
    1. Dell XPS 18 Touch Control Board Replacement, Touch Control Board: step 7, image 1 of 2 Dell XPS 18 Touch Control Board Replacement, Touch Control Board: step 7, image 2 of 2
      • Disconnect the black camera cable and pull it back to prevent future hassle.
      Ask FixBot
    2. Dell XPS 18 Touch Control Board Replacement: step 8, image 1 of 2 Dell XPS 18 Touch Control Board Replacement: step 8, image 2 of 2
      • Use the angled edge of the plastic opening tool to lift the clasp securing the touch control board cable.
      • Disconnect the silver and blue touch control board cable.
      Ask FixBot
    3. Dell XPS 18 Touch Control Board Replacement: step 9, image 1 of 2 Dell XPS 18 Touch Control Board Replacement: step 9, image 2 of 2
      • Remove the two silver 3mm screws holding the touch control board in place with a Phillips 00 screwdriver.
      • Remove the touch control board.
      Ask FixBot
4 other people completed this guide.
Austin Weir
1,308 Reputation
8 Guides authored
Cal Poly, Team 6-29, Amido Winter 2015 Member of Cal Poly, Team 6-29, Amido Winter 2015
CPSU-AMIDO-W15S6G29
4 Members
96 Guides authored
2 Guide Comments
It worked perfectly. Thank you.
Kenneth Macdonald - Reply Share
Which of Torx screwdrivers is used in step 1? As I can see, it is T8, but right above the Introduction section it is stated it is Torx T9...
Евгений Громов - Reply Share
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 27
All Time: 2,346
