Dell XPS 17 9710 SSD Replacement
Views: 2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
6
Past 30 Days:
35
All Time:
2,047
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Missing Steps
Oops! This guide is currently missing one or more important steps.
Archived Guide This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Introduction
Go to step 1 ↓
If your current SSD card in your Dell XPS17 9710 no longer has enough storage space or is failing, you may need to replace it.
Before replacing the SSD, make sure to back up any storage currently on the card to another hard drive.
Before beginning make sure to power off your device completely.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. Dell XPS 17 9710 SSD Replacement, Back Panel: step 1, image 1 of 2 Dell XPS 17 9710 SSD Replacement, Back Panel: step 1, image 2 of 2
      • Remove eight 5 mm screws from the back panel using a T5 Torx screwdriver.
      • Use the opening tool to loosen the panel on all sides and then lift it from the device.
      Ask FixBot
    1. Dell XPS 17 9710 SSD Replacement, SSD: step 2, image 1 of 2 Dell XPS 17 9710 SSD Replacement, SSD: step 2, image 2 of 2
      • Remove two 3 mm screws (four total) from each of the copper plates using a JIS #1 screwdriver.
      Ask FixBot
    2. Dell XPS 17 9710 SSD Replacement: step 3, image 1 of 2 Dell XPS 17 9710 SSD Replacement: step 3, image 2 of 2
      • Unplug the SSD card underneath each plate.
      • There may be two slots for SSD cards, but only one card. You can install another card for storage customizability in the laptop.
      Ask FixBot
Finish Line
Abigail Matos
308 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 35
All Time: 2,047
