Dell XPS 17 9710 RAM Replacement
    1. Dell XPS 17 9710 RAM Replacement, Prepare your device: step 1, image 1 of 1
      • For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of fire if the battery is accidentally damaged during the replacement. If your battery is swollen, take appropriate precautions.
      • Power off and unplug your laptop.
      • Close the display and flip the entire laptop upside-down, with the hinge facing away from you.
      Ask FixBot
    2. Dell XPS 17 9710 RAM Replacement, Remove the lower case screws: step 2, image 1 of 1
      • Use a Torx T5 screwdriver to remove the eight 4.4 mm-long screws that secure the lower case.
      • The lower case is further secured by various clips that must be released before removal.
      Ask FixBot
    3. Dell XPS 17 9710 RAM Replacement, Begin to release the clips: step 3, image 1 of 3 Dell XPS 17 9710 RAM Replacement, Begin to release the clips: step 3, image 2 of 3 Dell XPS 17 9710 RAM Replacement, Begin to release the clips: step 3, image 3 of 3
      • Insert an opening pick at the bottom left corner, between the lower case and the chassis.
      • Insert the flat end of a spudger into the gap created by the opening pick.
      • Pivot the spudger up to release the first set of retaining clips.
      • Repeat this process for the bottom right corner.
      Ask FixBot
    4. Dell XPS 17 9710 RAM Replacement, Release the remaining clips: step 4, image 1 of 3 Dell XPS 17 9710 RAM Replacement, Release the remaining clips: step 4, image 2 of 3 Dell XPS 17 9710 RAM Replacement, Release the remaining clips: step 4, image 3 of 3
      • Insert an opening pick into the gap created on the front edge of the laptop.
      • Slide the opening pick around the entire perimeter of the laptop, prying up intermittently, until the lower case fully releases from the clips on the chassis.
      Ask FixBot
    5. Dell XPS 17 9710 RAM Replacement, Remove the lower case: step 5, image 1 of 3 Dell XPS 17 9710 RAM Replacement, Remove the lower case: step 5, image 2 of 3 Dell XPS 17 9710 RAM Replacement, Remove the lower case: step 5, image 3 of 3
      • The lip of the lower case is very sharp. Handle it with care, and try not to slide your fingers along any of the edges.
      • Lift the lower case up and off of the chassis to remove it.
      Ask FixBot
    1. Dell XPS 17 9710 RAM Replacement, Dell XPS 17 9710 Battery Disconnection: step 6, image 1 of 3 Dell XPS 17 9710 RAM Replacement, Dell XPS 17 9710 Battery Disconnection: step 6, image 2 of 3 Dell XPS 17 9710 RAM Replacement, Dell XPS 17 9710 Battery Disconnection: step 6, image 3 of 3
      • Use the flat end of a spudger to pry the battery's connector up, directly out of its socket.
      • Alternatively, grip the battery connector pull tab with your fingers and lift straight up to disconnect it.
      • During reassembly, line the connector up with the socket and push down gently with a finger to reconnect it.
      • The connector should seat in place with minimal resistance. If it feels difficult to reconnect, realign the connector and try again.
      Ask FixBot
    1. Dell XPS 17 9710 RAM Replacement, Lift the mylar flap: step 7, image 1 of 2 Dell XPS 17 9710 RAM Replacement, Lift the mylar flap: step 7, image 2 of 2
      • Push over and hold down the mylar flap covering the RAM chip.
      Ask FixBot
    2. Dell XPS 17 9710 RAM Replacement, Release the RAM: step 8, image 1 of 2 Dell XPS 17 9710 RAM Replacement, Release the RAM: step 8, image 2 of 2
      • While holding down the flap, release the silver arms on each side of the RAM module by simultaneously pushing each arm away from the RAM.
      Ask FixBot
    3. Dell XPS 17 9710 RAM Replacement, Remove the RAM: step 9, image 1 of 2 Dell XPS 17 9710 RAM Replacement, Remove the RAM: step 9, image 2 of 2
      • Grip the free end of the RAM and pull it straight out of its socket.
      • Repeat this procedure for the second RAM module above if necessary.
      • When handling the RAM chips, touch only the outside edges. Take care not to touch the gold-colored contact points along the bottom edge.
      Ask FixBot
Connor Bassolino
26,106 Reputation
125 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,715 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 23
Past 30 Days: 94
All Time: 737
