Dell XPS 16 9640 Battery Replacement
    1. Dell XPS 16 9640 Battery Replacement, Battery: step 1, image 1 of 2 Dell XPS 16 9640 Battery Replacement, Battery: step 1, image 2 of 2
      • Use the Torx Plus 8IP screwdriver to remove eight 3.0 mm screws.
      Ask FixBot
    2. Dell XPS 16 9640 Battery Replacement: step 2, image 1 of 1
      • Pop open the back cover.
      • The cover is attached to the computer via clips around the perimeter.
      • Lift the lid up and off with your fingers.
      • If it is stuck, use a plastic opening tool to gently open it by wedging the tool under the cover and pushing down until the clip comes undone.
      Ask FixBot
    3. Dell XPS 16 9640 Battery Replacement: step 3, image 1 of 3 Dell XPS 16 9640 Battery Replacement: step 3, image 2 of 3 Dell XPS 16 9640 Battery Replacement: step 3, image 3 of 3
      • Use the Phillips #00 screwdriver to remove the six screws surrounding the battery.
      Ask FixBot
    4. Dell XPS 16 9640 Battery Replacement: step 4, image 1 of 1
      • Remove the battery by unfastening the clip where it is plugged into the computer.
      • Use the loop on the clip to lift the battery cable from the connection point in the computer. You can now gently pick up the battery.
      Ask FixBot
For optimal performance, calibrate your newly installed battery after completing this guide.
Caden Schomaker
109 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 59
All Time: 484
