Dell XPS 15-L502X RAM Replacement
    1. Dell XPS 15-L502X RAM Replacement, Back Panel: step 1, image 1 of 1
      • Remove the black battery bar from the computer before continuing any further operations.
      • Unscrew the three 5mm Phillps #2 screws on the left side of the back panel.
      Ask FixBot
    2. Dell XPS 15-L502X RAM Replacement: step 2, image 1 of 1
      • Lift up the left side of the panel.
      • There are three tabs holding in the right side of the panel. Pull the panel up and away from these tabs to remove it.
      Ask FixBot
    1. Dell XPS 15-L502X RAM Replacement, RAM: step 3, image 1 of 1
      • Locate both of the RAM slots right behind the back panel.
      Ask FixBot
    2. Dell XPS 15-L502X RAM Replacement: step 4, image 1 of 1
      • Use a black spudger to press the clips holding the RAM outward. You should hear a "click" sound.
      • Once both clips have been released, the RAM will be released at a 45 degree angle.
      Ask FixBot
    3. Dell XPS 15-L502X RAM Replacement: step 5, image 1 of 1
      • Carefully grab the RAM with both hands and pull outward.
      • Repeat steps 4 & 5 to remove the second RAM.
      • Both RAMs should come out without much force. Do not attempt to pull the RAM out with force as this could damage the fixture holding the RAM.
      Ask FixBot
Vishal
778 Reputation
6 Guides authored
IUPUI, Team 2-3, Baechle Fall 2015 Member of IUPUI, Team 2-3, Baechle Fall 2015
IUPUI-BAECHLE-F15S2G3
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 112
All Time: 2,794
