Dell XPS 15 9570 Wireless Card Replacement
Views: 3.9K
View statistics:
Past 24 Hours:
Past 7 Days:
27
Past 30 Days:
106
All Time:
3,863
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Assuming you aren't using an Ethernet cable or don't have an Ethernet adapter, this guide demonstrates how you can easily install your new wireless card adapter for your Dell XPS 15 9570. The reason you need a wireless adapter is to allow your computer to have access to the internet. The guide provides clear instructions on how to disassemble the computer and provides a correct way to install your wireless card adapter. Something to keep in mind during this process is to be careful when unscrewing the back plate, as the back plate could break. Also, make sure not to lose any of the screws, or else the back plate won't go on correctly. When you get to the back of the computer, make sure not to mess with any wiring, and only focus on the wireless adapter.
Tools
    1. Dell XPS 15 9570 Wireless Card Replacement, Base Cover: step 1, image 1 of 1
      • Make sure your device is powered off and unplugged before starting
      • Flip the device over so the base cover of the computer is facing upwards.
      Ask FixBot
    2. Dell XPS 15 9570 Wireless Card Replacement: step 2, image 1 of 3 Dell XPS 15 9570 Wireless Card Replacement: step 2, image 2 of 3 Dell XPS 15 9570 Wireless Card Replacement: step 2, image 3 of 3
      • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
      Ask FixBot
    3. Dell XPS 15 9570 Wireless Card Replacement: step 3, image 1 of 2 Dell XPS 15 9570 Wireless Card Replacement: step 3, image 2 of 2
      • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
      Ask FixBot
    4. Dell XPS 15 9570 Wireless Card Replacement: step 4, image 1 of 1
      • Lift the back cover off of the device.
      Ask FixBot
    1. Dell XPS 15 9570 Wireless Card Replacement, Wireless Card: step 5, image 1 of 2 Dell XPS 15 9570 Wireless Card Replacement, Wireless Card: step 5, image 2 of 2
      • Using a Phillips #00 screwdriver, loosen the captive screw holding the wireless card bracket in place.
      Ask FixBot
    2. Dell XPS 15 9570 Wireless Card Replacement: step 6, image 1 of 1
      • Lift the wireless card bracket off of the wireless card.
      Ask FixBot
    3. Dell XPS 15 9570 Wireless Card Replacement: step 7, image 1 of 2 Dell XPS 15 9570 Wireless Card Replacement: step 7, image 2 of 2
      • Using a spudger, disconnect the coaxial antenna cables from the Wi-Fi card by popping them gently off.
      Ask FixBot
    4. Dell XPS 15 9570 Wireless Card Replacement: step 8, image 1 of 1
      • Carefully remove the wireless card.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 27
Past 30 Days: 106
All Time: 3,863
