Dell XPS 15 9570 RAM Replacement
    1. Dell XPS 15 9570 RAM Replacement, Base Cover: step 1, image 1 of 1
      • Make sure your device is powered off and unplugged before starting
      • Flip the device over so the base cover of the computer is facing upwards.
      Ask FixBot
    2. Dell XPS 15 9570 RAM Replacement: step 2, image 1 of 3 Dell XPS 15 9570 RAM Replacement: step 2, image 2 of 3 Dell XPS 15 9570 RAM Replacement: step 2, image 3 of 3
      • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
      Ask FixBot
    3. Dell XPS 15 9570 RAM Replacement: step 3, image 1 of 2 Dell XPS 15 9570 RAM Replacement: step 3, image 2 of 2
      • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
      Ask FixBot
    4. Dell XPS 15 9570 RAM Replacement: step 4, image 1 of 1
      • Lift the back cover off of the device.
      Ask FixBot
    1. Dell XPS 15 9570 RAM Replacement, RAM: step 5, image 1 of 2 Dell XPS 15 9570 RAM Replacement, RAM: step 5, image 2 of 2
      • Use your fingers to pinch down the metal tabs holding the RAM in place. Do this for each tab.
      Ask FixBot
    2. Dell XPS 15 9570 RAM Replacement: step 6, image 1 of 1
      • Use your hands to carefully lift the RAM up and away from the tabs to safely take it out.
      Ask FixBot
1 Guide Comment
Does the battery connector need to be detached?
Rori Monni - Reply Share
Past 24 Hours: 2
Past 7 Days: 28
Past 30 Days: 94
All Time: 2,042
