Dell XPS 15 9570 Fan Replacement
    1. Dell XPS 15 9570 Fan Replacement, Base Cover: step 1, image 1 of 1
      • Make sure your device is powered off and unplugged before starting
      • Flip the device over so the base cover of the computer is facing upwards.
      Ask FixBot
    2. Dell XPS 15 9570 Fan Replacement: step 2, image 1 of 3 Dell XPS 15 9570 Fan Replacement: step 2, image 2 of 3 Dell XPS 15 9570 Fan Replacement: step 2, image 3 of 3
      • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
      Ask FixBot
    3. Dell XPS 15 9570 Fan Replacement: step 3, image 1 of 2 Dell XPS 15 9570 Fan Replacement: step 3, image 2 of 2
      • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
      Ask FixBot
    4. Dell XPS 15 9570 Fan Replacement: step 4, image 1 of 1
      • Lift the back cover off of the device.
      Ask FixBot
    1. Dell XPS 15 9570 Fan Replacement, Battery: step 5, image 1 of 1
      • Using the Phillips #00 screwdriver, remove the four 4 mm screws holding the battery in place.
      Ask FixBot
    2. Dell XPS 15 9570 Fan Replacement: step 6, image 1 of 1
      • Use the iFixit opening tool to disconnect the battery connector from the motherboard.
      Ask FixBot
    3. Dell XPS 15 9570 Fan Replacement: step 7, image 1 of 1
      • With your hands, pick up and remove the battery from the system.
      Ask FixBot
    1. Dell XPS 15 9570 Fan Replacement, Fan: step 8, image 1 of 2 Dell XPS 15 9570 Fan Replacement, Fan: step 8, image 2 of 2
      • Use the Phillips #00 screwdriver to remove the two 4 mm screws securing the grey display cable bracket.
      Ask FixBot
    2. Dell XPS 15 9570 Fan Replacement: step 9, image 1 of 1
      • Using the Phillips #00 screwdriver, remove the 4 mm screw at the back right corner of the fan.
      Ask FixBot
    3. Dell XPS 15 9570 Fan Replacement: step 10, image 1 of 2 Dell XPS 15 9570 Fan Replacement: step 10, image 2 of 2
      • Disconnect the fan cable on the left of the fan and on the right side from the RAM, using the opening tool.
      Ask FixBot
    4. Dell XPS 15 9570 Fan Replacement: step 11, image 1 of 1
      • Lift the right fan off of the device.
      • Repeat steps 8-11 to remove the left fan from the system board.
      • The left fan is fixed with two 4 mm screws. Make sure you have removed them if the fan does not come off easily.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 39
Past 30 Days: 120
All Time: 8,315
