Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓How to replace a scratched, cracked, or unresponsive touchpad on a Dell XPS 15 9560 laptop.
Before using this guide, check for other possible causes of touchpad issues.
- Trackpad Drivers: Your issue may be related to drivers. Watch this video by MDTechVideos for a fix.
- Dust or Debris: Clean the trackpad by spraying isopropyl alcohol on a microfiber cloth. Apply medium pressure and wipe in small circles on and around the trackpad.
Before you begin this repair, power off your laptop and unplug it from the charging adapter and any peripherals, like an external display.
Fix Kits
These kits contain all the parts and tools needed to complete this guide.
Parts
Tools
Use a Phillips screwdriver to remove the remaining 4 mm screws that secure the battery.
Using a Phillips #0 screwdriver, remove four 4.0 mm screws of the hard drive bracket.
Unplug the hard drive cable.
Disconnect the white ribbon cables, and use a spudger or your fingernail to gently lift the looped tab away from the connector. It should pop up easily.
Next, use the spudger or your fingernail to push the plastic tab away from the socket. It should move slightly.
Now, pull the white ribbon cables out.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
