Dell XPS 15 9560 Solid State Drive (SSD) Replacement
    1. Dell XPS 15 9560 Solid State Drive (SSD) Replacement, Back Panel: step 1, image 1 of 1
      • Before beginning, unplug the charger and any peripheries. If possible, discharge your battery below 25%.
      • Shut the laptop down.
      Ask FixBot
    2. Dell XPS 15 9560 Solid State Drive (SSD) Replacement: step 2, image 1 of 1
      • Remove the ten 4.0 mm screws from the back panel of the laptop using a T5 Torx screwdriver.
      Ask FixBot
    3. Dell XPS 15 9560 Solid State Drive (SSD) Replacement: step 3, image 1 of 1
      • Remove the two 5 mm screws underneath the XPS badge door using a Phillips screwdriver
      Ask FixBot
    4. Dell XPS 15 9560 Solid State Drive (SSD) Replacement: step 4, image 1 of 1
      • Use a scribe to remove the bottom base cover from the backplate.
      Ask FixBot
    1. Dell XPS 15 9560 Solid State Drive (SSD) Replacement, Solid State Drive (SSD): step 5, image 1 of 1
      • Using a Phillips #2 screwdriver, remove a single 3.0 mm screw from the SSD bracket.
      Ask FixBot
    2. Dell XPS 15 9560 Solid State Drive (SSD) Replacement: step 6, image 1 of 1
      • Using the same Phillips #2 screwdriver, unscrew and remove one 2.0 mm wafer screw from the SSD bracket.
      Ask FixBot
    3. Dell XPS 15 9560 Solid State Drive (SSD) Replacement: step 7, image 1 of 1
      • Pull out and separate the SSD bracket and SSD, replacing the old SSD with a new one.
      Ask FixBot
Frederick Rowell
196 Reputation
1 Guide authored
Clemson, Team 4-5, Hunter Fall 2021 Member of Clemson, Team 4-5, Hunter Fall 2021
CLEM-HUNTER-F21S4G5
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 51
All Time: 3,627
