Dell XPS 15 9560 Hard Drive Replacement
    1. Dell XPS 15 9560 Hard Drive Replacement, Back Panel: step 1, image 1 of 1
      • Before beginning, unplug the charger and any peripheries. If possible, discharge your battery below 25%.
      • Shut the laptop down.
      Ask FixBot
    2. Dell XPS 15 9560 Hard Drive Replacement: step 2, image 1 of 1
      • Remove the ten 4.0 mm screws from the back panel of the laptop using a T5 Torx screwdriver.
      Ask FixBot
    3. Dell XPS 15 9560 Hard Drive Replacement: step 3, image 1 of 1
      • Remove the two 5 mm screws underneath the XPS badge door using a Phillips screwdriver
      Ask FixBot
    4. Dell XPS 15 9560 Hard Drive Replacement: step 4, image 1 of 1
      • Use a scribe to remove the bottom base cover from the backplate.
      Ask FixBot
    1. Dell XPS 15 9560 Hard Drive Replacement, Hard Drive: step 5, image 1 of 1
      • Using a Phillips #0 screwdriver, remove four 4.0 mm screws of the hard drive bracket.
      • Unplug the hard drive cable.
      Ask FixBot
    2. Dell XPS 15 9560 Hard Drive Replacement: step 6, image 1 of 1
      • Remove the hard drive bracket. Then, unplug and remove the hard drive.
      Ask FixBot
Jada Houser
884 Reputation
7 Guides authored
Clemson, Team 4-5, Hunter Fall 2021 Member of Clemson, Team 4-5, Hunter Fall 2021
CLEM-HUNTER-F21S4G5
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 13
Past 30 Days: 41
All Time: 4,130
