Dell XPS 15 9560 Battery Replacement
    1. Dell XPS 15 9560 Battery  Replacement, Back Panel: step 1, image 1 of 1
      • Before beginning, unplug the charger and any peripheries. If possible, discharge your battery below 25%.
      • Shut the laptop down.
      Ask FixBot
    2. Dell XPS 15 9560 Battery  Replacement: step 2, image 1 of 1
      • Remove the ten 4.0 mm screws from the back panel of the laptop using a T5 Torx screwdriver.
      Ask FixBot
    3. Dell XPS 15 9560 Battery  Replacement: step 3, image 1 of 1
      • Remove the two 5 mm screws underneath the XPS badge door using a Phillips screwdriver
      Ask FixBot
    4. Dell XPS 15 9560 Battery  Replacement: step 4, image 1 of 1
      • Use a scribe to remove the bottom base cover from the backplate.
      Ask FixBot
    1. Dell XPS 15 9560 Battery  Replacement, Battery: step 5, image 1 of 1
      • Using a T5 Torx screwdriver, remove the six 4.0 mm screws.
      Ask FixBot
    2. Dell XPS 15 9560 Battery  Replacement: step 6, image 1 of 1
      • Use your fingernails to gently "walk" the battery connector directly out of its socket.
      Ask FixBot
    3. Dell XPS 15 9560 Battery  Replacement: step 7, image 1 of 1
      • Remove the battery.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
12 other people completed this guide.
Jada Houser
884 Reputation
7 Guides authored
Clemson, Team 4-5, Hunter Fall 2021 Member of Clemson, Team 4-5, Hunter Fall 2021
CLEM-HUNTER-F21S4G5
4 Members
96 Guides authored
1 Guide Comment
If you have an additional HDD you need to use the type H5H20 instead of the 6GPTY. The configuration as shown in picture 6 isn't possible with the 6GPTY unless you're willing to remove the HDD.
Tim - Reply Share
Past 24 Hours: 12
Past 7 Days: 74
Past 30 Days: 307
All Time: 15,862
