Dell XPS 15 9550 RAM Replacement
    1. Dell XPS 15 9550 RAM Replacement, Back/Underside Panel: step 1, image 1 of 1
      • Turn the laptop upside down.
      • Make sure the laptop is turned off.
      • Use a T5 Torx Screwdriver to remove the ten 3 mm long screws from the perimeter of the back of the laptop.
      Ask FixBot
    2. Dell XPS 15 9550 RAM Replacement: step 2, image 1 of 2 Dell XPS 15 9550 RAM Replacement: step 2, image 2 of 2
      • Open up the information panel door (on the middle of the back side).
      • While holding the door open, use a Phillips #00 Screwdriver to remove the two 10 mm long screws.
      Ask FixBot
    3. Dell XPS 15 9550 RAM Replacement: step 3, image 1 of 3 Dell XPS 15 9550 RAM Replacement: step 3, image 2 of 3 Dell XPS 15 9550 RAM Replacement: step 3, image 3 of 3
      • Carefully lift the 2 corners of the back panel close to the hinge upwards, to release the whole panel.
      • Do not force the panel off. If it does not come off easily, try to use a plastic spudger where it is stuck.
      Ask FixBot
    1. Dell XPS 15 9550 RAM Replacement, RAM: step 4, image 1 of 2 Dell XPS 15 9550 RAM Replacement, RAM: step 4, image 2 of 2
      • There are 2 separate RAM sticks.
      • Gently push down on the 2 outside tabs of the RAM stick you want to replace.
      • While still pushing down, gently push the tabs outwards, causing the RAM stick to flip up.
      Ask FixBot
    2. Dell XPS 15 9550 RAM Replacement: step 5, image 1 of 2 Dell XPS 15 9550 RAM Replacement: step 5, image 2 of 2
      • Firmly grasp the RAM stick from the flipped up edge and gently pull out, to release the RAM stick.
      Ask FixBot
6 other people completed this guide.
jbaseballin2
123 Reputation
1 Guide authored
UW Stout, Team S6-G1, Ogden Fall 2018 Member of UW Stout, Team S6-G1, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G1
4 Members
60 Guides authored
1 Guide Comment
What type ram do you replace it with? Could you post a link?
twrfan - Reply Share
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 84
All Time: 9,853
