Dell XPS 15 9530 WiFi Card Replacement
    1. Dell XPS 15 9530 WiFi Card Replacement, Base Cover: step 1, image 1 of 3 Dell XPS 15 9530 WiFi Card Replacement, Base Cover: step 1, image 2 of 3 Dell XPS 15 9530 WiFi Card Replacement, Base Cover: step 1, image 3 of 3
      • Using a T5 Torx screwdriver, remove ten 3mm screws.
      Ask FixBot
    2. Dell XPS 15 9530 WiFi Card Replacement: step 2, image 1 of 2 Dell XPS 15 9530 WiFi Card Replacement: step 2, image 2 of 2
      • Lift the plastic tab.
      • Remove two 3mm Phillips #0 screws under the plastic tab.
      Ask FixBot
    3. Dell XPS 15 9530 WiFi Card Replacement: step 3, image 1 of 1
      • Lift the lower case off.
      Ask FixBot
    1. Dell XPS 15 9530 WiFi Card Replacement, WiFi Card: step 4, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the screw holding the WiFi card down. Be careful not to lose the metal retainer holding the antenna cables down.
      • Without applying too much force, pop out the antenna cables and remove the card.
      • Insert the new card, and reattach the antenna cables. The black cable connects to the main antenna slot (marked with a solid triangle) and the white connects to the auxiliary (marked with an empty triangle).
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 41
All Time: 2,914
