Dell XPS 15 9530 Screen Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
88
All Time:
2,551
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Removal of the screen will be covered in this guide. To successfully remove the battery, a #0 Phillips screwdriver, a T5 Torx screwdriver, tweezers, and a plastic spudger are needed. Be careful disconnecting cables as to not break them or their connectors.
Tools
    1. Dell XPS 15 9530 Screen Replacement, Base Cover: step 1, image 1 of 3 Dell XPS 15 9530 Screen Replacement, Base Cover: step 1, image 2 of 3 Dell XPS 15 9530 Screen Replacement, Base Cover: step 1, image 3 of 3
      • Using a T5 Torx screwdriver, remove ten 3mm screws.
      Ask FixBot
    2. Dell XPS 15 9530 Screen Replacement: step 2, image 1 of 2 Dell XPS 15 9530 Screen Replacement: step 2, image 2 of 2
      • Lift the plastic tab.
      • Remove two 3mm Phillips #0 screws under the plastic tab.
      Ask FixBot
    3. Dell XPS 15 9530 Screen Replacement: step 3, image 1 of 1
      • Lift the lower case off.
      Ask FixBot
    1. Dell XPS 15 9530 Screen Replacement, Battery: step 4, image 1 of 2 Dell XPS 15 9530 Screen Replacement, Battery: step 4, image 2 of 2
      • Using a Phillips #0 screwdriver, remove the seven 3.5mm screws that secure the battery to the palm rest assembly.
      Ask FixBot
    2. Dell XPS 15 9530 Screen Replacement: step 5, image 1 of 1
      • Disconnect the battery cable from the system board.
      • Be sure to use a plastic tool, not a metal one.
      Ask FixBot
    3. Dell XPS 15 9530 Screen Replacement: step 6, image 1 of 1
      • Lift the battery off the chassis.
      Ask FixBot
    1. Dell XPS 15 9530 Screen Replacement, SSD: step 7, image 1 of 1
      • Pull lift tabs and remove the plastic that covers the hard drive to expose the hard drive.
      Ask FixBot
    2. Dell XPS 15 9530 Screen Replacement: step 8, image 1 of 2 Dell XPS 15 9530 Screen Replacement: step 8, image 2 of 2
      • Using a Phillips #0 screwdriver, remove two 2.5mm screws that secure the SSD to the chassis.
      Ask FixBot
    3. Dell XPS 15 9530 Screen Replacement: step 9, image 1 of 1
      • Pull the SSD out parallel to the mainboard.
      Ask FixBot
    1. Dell XPS 15 9530 Screen Replacement, Screen: step 10, image 1 of 2 Dell XPS 15 9530 Screen Replacement, Screen: step 10, image 2 of 2
      • Unplug the screen connector.
      Ask FixBot
    2. Dell XPS 15 9530 Screen Replacement: step 11, image 1 of 2 Dell XPS 15 9530 Screen Replacement: step 11, image 2 of 2
      • Using a Phillips #0 screwdriver, remove the four 4mm screws holding in the screen hinges.
      Ask FixBot
    3. Dell XPS 15 9530 Screen Replacement: step 12, image 1 of 1
      • Pull chassis away from screen assembly.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 88
All Time: 2,551
