Up to 20% off select tools
Dell XPS 15 9530 Memory Module Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
87
All Time:
1,888
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 - 8 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
How to replace the memory modules of a Dell XPS 15 9530.
    1. Dell XPS 15 9530 Memory Module Replacement, Unscrewing the Base-Cover Assembly: step 1, image 1 of 1
      • After turning off the system, unscrew the 12 Philips screws (#1) that are on the bottom of the laptop.
      • Don't forget to unscrew the two screws hidden under the system badge!
      Ask FixBot
    2. Dell XPS 15 9530 Memory Module Replacement, Prying Off the Base-Cover Assembly: step 2, image 1 of 1
      • Using a spudger or some other prying tool (#1), pry off the base-cover assembly from the rest of the system.
      Ask FixBot
    1. Dell XPS 15 9530 Memory Module Replacement, Remove Battery: step 3, image 1 of 1
      • Remove the screws that secure the battery to the palm-rest assembly.
      • Disconnect the battery cable from the system board.
      • Lift the battery off the palm-rest assembly.
      • After you remove the battery, turn the computer over, open the display, and press the power button for about five seconds to ground the system board.
      Ask FixBot
    1. Dell XPS 15 9530 Memory Module Replacement, Remove Memory: step 4, image 1 of 1
      • Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module connector until the memory module pops up.
      • Remove the memory module from the memory-module connector.
      Ask FixBot
    2. Dell XPS 15 9530 Memory Module Replacement, Add New Memory Module: step 5, image 1 of 1
      • Align the notch on the New memory module with the tab on the memory-module connector.
      • Slide the memory module firmly into the connector at a 45-degree angle and press the memory module down until it clicks into place.
      • NOTE: If you do not hear the click, remove the memory module and reinstall it.
      Ask FixBot
To reassemble your device, put the battery back in and reaffix the base-cover assembly to the system.
Author
with
Johnathan Hammond
46,425 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 87
All Time: 1,888
