Dell XPS 15 9530 Keyboard Replacement
    1. Dell XPS 15 9530 Keyboard Replacement, Base Cover: step 1, image 1 of 3 Dell XPS 15 9530 Keyboard Replacement, Base Cover: step 1, image 2 of 3 Dell XPS 15 9530 Keyboard Replacement, Base Cover: step 1, image 3 of 3
      • Using a T5 Torx screwdriver, remove ten 3mm screws.
      Ask FixBot
    2. Dell XPS 15 9530 Keyboard Replacement: step 2, image 1 of 2 Dell XPS 15 9530 Keyboard Replacement: step 2, image 2 of 2
      • Lift the plastic tab.
      • Remove two 3mm Phillips #0 screws under the plastic tab.
      Ask FixBot
    3. Dell XPS 15 9530 Keyboard Replacement: step 3, image 1 of 1
      • Lift the lower case off.
      Ask FixBot
    1. Dell XPS 15 9530 Keyboard Replacement, Battery: step 4, image 1 of 2 Dell XPS 15 9530 Keyboard Replacement, Battery: step 4, image 2 of 2
      • Using a Phillips #0 screwdriver, remove the seven 3.5mm screws that secure the battery to the palm rest assembly.
      Ask FixBot
    2. Dell XPS 15 9530 Keyboard Replacement: step 5, image 1 of 1
      • Disconnect the battery cable from the system board.
      • Be sure to use a plastic tool, not a metal one.
      Ask FixBot
    3. Dell XPS 15 9530 Keyboard Replacement: step 6, image 1 of 1
      • Lift the battery off the chassis.
      Ask FixBot
    1. Dell XPS 15 9530 Keyboard Replacement, Keyboard: step 7, image 1 of 3 Dell XPS 15 9530 Keyboard Replacement, Keyboard: step 7, image 2 of 3 Dell XPS 15 9530 Keyboard Replacement, Keyboard: step 7, image 3 of 3
      • Remove the three 3.5mm Phillips #0 screws mounting the motherboard.
      Ask FixBot
    2. Dell XPS 15 9530 Keyboard Replacement: step 8, image 1 of 3 Dell XPS 15 9530 Keyboard Replacement: step 8, image 2 of 3 Dell XPS 15 9530 Keyboard Replacement: step 8, image 3 of 3
      Tool used on this step:
      Buy
      • Disconnect ribbon cables above the touch pad using tweezers.
      Ask FixBot
    3. Dell XPS 15 9530 Keyboard Replacement: step 9, image 1 of 3 Dell XPS 15 9530 Keyboard Replacement: step 9, image 2 of 3 Dell XPS 15 9530 Keyboard Replacement: step 9, image 3 of 3
      • Lift and remove the motherboard from the chassis.
      Ask FixBot
    4. Dell XPS 15 9530 Keyboard Replacement: step 10, image 1 of 3 Dell XPS 15 9530 Keyboard Replacement: step 10, image 2 of 3 Dell XPS 15 9530 Keyboard Replacement: step 10, image 3 of 3
      • Remove the ten 3mm Phillips #0 screws on the perimeter of the keyboard assembly.
      • Remove the ten 2.5mm Phillips #0 screws underneath the plastic shielding of the keyboard.
      Ask FixBot
1 Guide Comment
Thank you for this guide! Is there any way to obtain replacement screws for the outer perimeter of the keyboard? I’ve recently disassembled my XPS 9530 and found one of the screws is very stripped, I managed to get it out but it really shouldn’t be put back in due to the state of the head.
I’m struggling to find replacements for the size quoted. Are they Phillips M2 3mm silver screws?
James White - Reply Share
Past 24 Hours: 3
Past 7 Days: 28
Past 30 Days: 101
All Time: 7,959
