Dell XPS 15 9530 Fan Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
Past 7 Days:
21
Past 30 Days:
90
All Time:
2,074
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The Dell XPS 15 9530 touchscreen laptop has an easily accessible fan that is relatively simple to replace. The purpose of the fan is to distribute cool air over the internal components of the laptop and prevent them from overheating. If the laptop is generating excessive noise or heat, the fan should be inspected for dust or blockage. Use a dry microfiber cloth or compressed air to clean the fan. If problems persist, it may be time to replace the fan. Make sure to perform any maintenance on a flat non-carpet surface and use ESD-safe tools to prevent static buildup. Turn off the laptop entirely and back up any crucial data before opening up back panel.
Tools
    1. Dell XPS 15 9530 Fan Replacement, Fan: step 1, image 1 of 3 Dell XPS 15 9530 Fan Replacement, Fan: step 1, image 2 of 3 Dell XPS 15 9530 Fan Replacement, Fan: step 1, image 3 of 3
      • Turn the laptop upside down.
      • Unscrew ten 3 mm screws on the back cover with a Torx T5 screwdriver.
      • Remove two more 3 mm screws with a Phillips #0 screwdriver.
      Ask FixBot
    2. Dell XPS 15 9530 Fan Replacement: step 2, image 1 of 2 Dell XPS 15 9530 Fan Replacement: step 2, image 2 of 2
      • Use the Phillips #0 screwdriver to unscrew the three screws on each fan.
      Ask FixBot
    3. Dell XPS 15 9530 Fan Replacement: step 3, image 1 of 2 Dell XPS 15 9530 Fan Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Use metal tweezers to carefully unplug the fan cables from the motherboard.
      Ask FixBot
    4. Dell XPS 15 9530 Fan Replacement: step 4, image 1 of 1
      • Remove the fans by gently lifting up the edges until the fans disconnect from the motherboard completely.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 21
Past 30 Days: 90
All Time: 2,074
