Dell XPS 15 9530 Battery Replacement
    1. Dell XPS 15 9530 Battery Replacement, Base Cover: step 1, image 1 of 3 Dell XPS 15 9530 Battery Replacement, Base Cover: step 1, image 2 of 3 Dell XPS 15 9530 Battery Replacement, Base Cover: step 1, image 3 of 3
      • Using a T5 Torx screwdriver, remove ten 3mm screws.
      Ask FixBot
    2. Dell XPS 15 9530 Battery Replacement: step 2, image 1 of 2 Dell XPS 15 9530 Battery Replacement: step 2, image 2 of 2
      • Lift the plastic tab.
      • Remove two 3mm Phillips #0 screws under the plastic tab.
      Ask FixBot
    3. Dell XPS 15 9530 Battery Replacement: step 3, image 1 of 1
      • Lift the lower case off.
      Ask FixBot
    1. Dell XPS 15 9530 Battery Replacement, Battery: step 4, image 1 of 2 Dell XPS 15 9530 Battery Replacement, Battery: step 4, image 2 of 2
      • Using a Phillips #0 screwdriver, remove the seven 3.5mm screws that secure the battery to the palm rest assembly.
      Ask FixBot
    2. Dell XPS 15 9530 Battery Replacement: step 5, image 1 of 1
      • Disconnect the battery cable from the system board.
      • Be sure to use a plastic tool, not a metal one.
      Ask FixBot
    3. Dell XPS 15 9530 Battery Replacement: step 6, image 1 of 1
      • Lift the battery off the chassis.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 100
All Time: 5,347
