Dell XPS 15 9530 Battery Replacement
    1. Dell XPS 15 9530 Battery Replacement, Unscrewing the Base-Cover Assembly: step 1, image 1 of 1
      • After turning off the system, unscrew the 12 Philips screws (#1) that are on the bottom of the laptop.
      • Don't forget to unscrew the two screws hidden under the system badge!
      Ask FixBot
    2. Dell XPS 15 9530 Battery Replacement, Prying Off the Base-Cover Assembly: step 2, image 1 of 1
      • Using a spudger or some other prying tool (#1), pry off the base-cover assembly from the rest of the system.
      Ask FixBot
    1. Dell XPS 15 9530 Battery Replacement, Remove Battery: step 3, image 1 of 1
      • Remove the screws that secure the battery to the palm-rest assembly.
      • Disconnect the battery cable from the system board.
      • Lift the battery off the palm-rest assembly.
      • After you remove the battery, turn the computer over, open the display, and press the power button for about five seconds to ground the system board.
      Ask FixBot
5 other people completed this guide.
Johnathan Hammond
46,185 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,172 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 55
All Time: 4,276
