Dell XPS 15 9530 Base-Cover Assembly Replacement
    1. Dell XPS 15 9530 Base-Cover Assembly Replacement, Unscrewing the Base-Cover Assembly: step 1, image 1 of 1
      • After turning off the system, unscrew the 12 Philips screws (#1) that are on the bottom of the laptop.
      • Don't forget to unscrew the two screws hidden under the system badge!
      Ask FixBot
    2. Dell XPS 15 9530 Base-Cover Assembly Replacement, Prying Off the Base-Cover Assembly: step 2, image 1 of 1
      • Using a spudger or some other prying tool (#1), pry off the base-cover assembly from the rest of the system.
      Ask FixBot
William Daniels
824 Reputation
6 Guides authored
2 Guide Comments
I need to replace these screws. What is the size, dimension, type?
Jason Benci - Reply Share
There is no "system badge" which folds open on my Dell XPS 15 9530 (2023). It is solid aluminum, and has "XPS" stamped into it. The images published for this repair guide appear as if the bottom cover is made of some kind of plastic? Am I looking at the wrong repair guide?
Tom Farrell - Reply Share
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 46
All Time: 1,108
