Dell XPS 15 9520 Back Cover Replacement
    1. Dell XPS 15 9520 Back Cover Replacement, Unfasten the back cover: step 1, image 1 of 2 Dell XPS 15 9520 Back Cover Replacement, Unfasten the back cover: step 1, image 2 of 2
      • For your safety, discharge the battery below 25% and power down your device before disassembly.
      • Use a Torx T5 screwdriver to remove the eight 3.3 mm-long screws securing the back cover.
      Ask FixBot
    2. Dell XPS 15 9520 Back Cover Replacement, Insert an opening pick: step 2, image 1 of 2 Dell XPS 15 9520 Back Cover Replacement, Insert an opening pick: step 2, image 2 of 2
      • Insert an opening pick between the bottom-left corner of the aluminum back cover and the chassis.
      • Leave the pick inserted before continuing to the next step.
      Ask FixBot
    3. Dell XPS 15 9520 Back Cover Replacement, Release the corner clip: step 3, image 1 of 2 Dell XPS 15 9520 Back Cover Replacement, Release the corner clip: step 3, image 2 of 2
      • Insert the flat end of the spudger into the gap you just created.
      • Pry up to release the corner clips.
      • Repeat this process for the opposite corner of the back cover.
      Ask FixBot
    4. Dell XPS 15 9520 Back Cover Replacement, Unclip the front edge: step 4, image 1 of 3 Dell XPS 15 9520 Back Cover Replacement, Unclip the front edge: step 4, image 2 of 3 Dell XPS 15 9520 Back Cover Replacement, Unclip the front edge: step 4, image 3 of 3
      • Reinsert your opening pick under the aluminum cover at the front edge of the laptop.
      • Pry to loosen the cover.
      • Pry at multiple locations along the front edge to release all of the retaining clips.
      • Do not use a sliding motion along the front edge. This may damage cables near the trackpad.
      Ask FixBot
    5. Dell XPS 15 9520 Back Cover Replacement, Remove the back cover: step 5, image 1 of 3 Dell XPS 15 9520 Back Cover Replacement, Remove the back cover: step 5, image 2 of 3 Dell XPS 15 9520 Back Cover Replacement, Remove the back cover: step 5, image 3 of 3
      • The edges of the back cover are very sharp. Use caution when handling it.
      • Lift the back cover off the chassis and remove it.
      • If the back cover feels stuck to the chassis, use an opening pick to release any remaining clips around the back cover's perimeter.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Dell XPS answers community for help.
4 other people completed this guide.
Clay Eickemeyer
106,250 Reputation
472 Guides authored
3 Guide Comments
Would these same steps be followed for the Dell XPS 15 2023 (9530) model?
Matt - Reply Share
While we can't say for sure without having the device in our hands, the back cover comes off relatively the same between newer XPS models. A Torx driver and unclipping the front half of the cover will more than likely get you into the laptop.
Clay Eickemeyer - Reply Share
Hi everyone, first of all I wanted to appreciate the accurate and informative information regarding the replacement, but I had a question about changing the bottom cover. Since there is the number of mariculation on the aluminium cover, won't it be risky changing it? Or at least if you ask dell, will thay make another cover for you with your matriculation num? How much does it cost more less? Thank you in advanced for your gentle responce.
Kasra Akbari - Reply Share
Past 24 Hours: 9
Past 7 Days: 36
Past 30 Days: 124
All Time: 9,405
