Dell XPS 15 9510 RAM Replacement
    1. Dell XPS 15 9510 RAM Replacement, Lower Case: step 1, image 1 of 1
      • Make sure the laptop is powered off and unplug all cables before beginning any repair.
      • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
      Ask FixBot
    2. Dell XPS 15 9510 RAM Replacement: step 2, image 1 of 1
      • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
      • Wedge the case apart with a nylon spudger.
      • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
      • Slide spudger along each side of the laptop
      Ask FixBot
    3. Dell XPS 15 9510 RAM Replacement: step 3, image 1 of 1
      • Lift the back panel of the laptop off and set it aside.
      Ask FixBot
    1. Dell XPS 15 9510 RAM Replacement, RAM: step 4, image 1 of 1
      • Using both hands, pull the clips that hold the RAM in place.
      Ask FixBot
    2. Dell XPS 15 9510 RAM Replacement: step 5, image 1 of 2 Dell XPS 15 9510 RAM Replacement: step 5, image 2 of 2
      • Gently, with both hands, pull the RAM up at a 45º angle and take out the RAM.
      • Repeat the same process with the other RAM.
      Ask FixBot
Bethany Wright
439 Reputation
3 Guides authored
IUPUI, Team 2-1, Harley Summer 2023 Member of IUPUI, Team 2-1, Harley Summer 2023
IUPUI-HARLEY-SU23S2G1
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 107
All Time: 2,222
