Dell XPS 15 9500 Fan Replacement
    1. Dell XPS 15 9500 Fan Replacement, Base Panel: step 1, image 1 of 1
      • Remove the eight 3.0 mm screws from the bottom panel with a T5 Torx screwdriver.
      Ask FixBot
    2. Dell XPS 15 9500 Fan Replacement: step 2, image 1 of 2 Dell XPS 15 9500 Fan Replacement: step 2, image 2 of 2
      • Gently wedge an opening tool in the gap between the base panel and chassis, and pry vertically around the perimeter until it releases from the chassis.
      • Lift the base panel up and away from the chassis.
      Ask FixBot
    1. Dell XPS 15 9500 Fan Replacement, Fan: step 3, image 1 of 2 Dell XPS 15 9500 Fan Replacement, Fan: step 3, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the two 4.0 mm screws screws from each fan (four screws total).
      Ask FixBot
    2. Dell XPS 15 9500 Fan Replacement: step 4, image 1 of 1
      • Use an opening tool to push the left fan cable plug out of its socket.
      • Repeat for right fan cable.
      Ask FixBot
    3. Dell XPS 15 9500 Fan Replacement: step 5, image 1 of 1
      • Lift the fan up and away from the heatsink.
      • Repeat for the right fan.
      Ask FixBot
Bryan Chung
452 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 30
Past 30 Days: 109
All Time: 3,071
