Dell XPS 15 9500 Battery Replacement
      • Save and close all open files and exit all open applications.
      • Shut down your computer. Click Start > Power > Shut down.
      • Disconnect your computer and all attached devices from their electrical outlets.
      • Disconnect all attached network devices and peripherals, such as keyboard, mouse, and monitor from your computer.
      • Remove any media card and optical disc from your computer, if applicable.
      Ask FixBot
    1. Dell XPS 15 9500 Battery Replacement, Remove the base cover screws: step 2, image 1 of 1
      • Use a T5 Torx screwdriver to remove the eight 3 mm screws that secure the base cover to the palm-rest and keyboard assembly.
      Ask FixBot
    2. Dell XPS 15 9500 Battery Replacement, Remove the base cover: step 3, image 1 of 1
      • Starting from the bottom-left corner, use a plastic scribe (spudger) to pry the base cover in the direction of the arrows to release the base cover from the palm-rest and keyboard assembly.
      • Grasp the left side and the right side of the base cover and remove the base cover from the palm-rest and keyboard assembly.
      • The edges of the base cover are very sharp. Use caution when handling it.
      Ask FixBot
    3. Dell XPS 15 9500 Battery Replacement, Disconnect battery cable: step 4, image 1 of 1
      • Disconnect the battery cable from the system board.
      Ask FixBot
    4. Dell XPS 15 9500 Battery Replacement, Drain the flea power: step 5, image 1 of 1
      • Turn your computer over and press the power button for 15 seconds to drain the flea power.
      Ask FixBot
    5. Dell XPS 15 9500 Battery Replacement, Remove the battery: step 6, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the four screws (M2x4) that secure the battery to the palm-rest and keyboard assembly.
      • Remove the four Phillips #1 screws (M2x3) that secure the battery to the palm-rest and keyboard assembly.
      • Peel the tapes that secure the speaker cable to the battery.
      • Lift the battery off the palm-rest and keyboard assembly.
      Ask FixBot
To replace the battery & reassemble your device, follow these instructions in reverse order.
10 other people completed this guide.
Max Kletskov
42,058 Reputation
16 Guides authored
13 Guide Comments
It seems there are issues with replacement Dell batteries causing the touchpad to behave erratically (https://www.dell.com/community/XPS/xps-1...), with impaired action of the left 'mouse button' on the pad, and the left button either clicking randomly or appearing to be held down. Have returned a (so-called) compatible 3rd party battery for my XPS15 9500 and now going to try an original Dell replacement. The problem seems to be battery thickness, i.e. not giving the touchpad room to correctly operate.
Simon Conway-Smith - Reply Share
Interesting point. I just removed my original Dell battery b/c the cells swelled and pushed the bottom of the touchpad up causing the corners to no longer left/right click. Also, some keys stopped working. Waiting on my replacement "compatible" battery to arrive.
Zoren Too - Reply Share
It should also be noted that most replacement batteries don't come with the battery connection cable, so you need to remove it from the existing battery and install it on the replacement. The cable seems to come off with a slight pull (once unstuck and the securing tape next to the connector is lifted), and inserts onto the new battery by just pushing it down onto the connector.
Actually I think this may the best way to install the battery. I could easily see damaging the motherboard trying to disconnect the cable from the motherboard.
Jeff G. - Reply Share
Yes, I can confirm that you do not need to disconnect the battery cable from the motherboard. You can leave that connection but remove the connection to the existing battery. There will be a lot of sticky stuff to get through as it the cable thingy is stuck to the battery, but it should just kind of like pop right out once you get all the sticky stuff and then you can just plug that right into your new battery without ever disrupting the battery to motherboard connection
Tony Liao - Reply Share
Past 24 Hours: 23
Past 7 Days: 169
Past 30 Days: 737
All Time: 27,248
