Dell XPS 14Z L412Z Fan Replacement
    1. Dell XPS 14Z L412Z  Fan Replacement, Back Panel: step 1, image 1 of 1
      • Remove the back cover of the laptop by unscrewing eight 3.5mm screws using a Phillips #0 screwdriver.
      Ask FixBot
    2. Dell XPS 14Z L412Z  Fan Replacement: step 2, image 1 of 2 Dell XPS 14Z L412Z  Fan Replacement: step 2, image 2 of 2
      • Using the plastic opening tool, pry up the back cover.
      • It is recommended to start from a corner and run the tool along the edge of the cover.
      Ask FixBot
    1. Dell XPS 14Z L412Z  Fan Replacement, Cooling Fan: step 3, image 1 of 2 Dell XPS 14Z L412Z  Fan Replacement, Cooling Fan: step 3, image 2 of 2
      • The fan is located on the upper right hand side of the laptop.
      • Unscrew the four 4.5mm Phillips #0 screws along the fan.
      Ask FixBot
    2. Dell XPS 14Z L412Z  Fan Replacement: step 4, image 1 of 2 Dell XPS 14Z L412Z  Fan Replacement: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Disconnect the fan connection by using the metal tweezers.
      • Then, plug in the new or cleaned fan back into the connection.
      Ask FixBot
Cole Hanson
144 Reputation
1 Guide authored
UW Stout, Team S8-G3, Ogden Spring 2018 Member of UW Stout, Team S8-G3, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G3
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 66
All Time: 1,173
