Up to 20% off select tools
Dell XPS 14 RAM Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
14
Past 30 Days:
89
All Time:
992
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The device featured in this replacement guide is the Dell XPS 14 L421X. This guide will assist the user in removing and replacing the laptop's RAM. There are no special skills or requirements for this guide, the user will only need to complete the steps shown. The RAM may often be the cause for random crashes or display issues. For more troubleshooting information, refer to the troubleshooting page. Before fully removing the RAM, make sure you check to ensure that the RAM is connected to the device, as these symptoms may also be due to a loose cable or plug. Before following these steps, it is important that you ground yourself by wearing an anti-static wrist strap. Also, make sure that the battery is fully disconnected before removing the RAM.
    1. Dell XPS 14 RAM Replacement, Back Panel: step 1, image 1 of 1
      • Position the computer back side up so that the “XPS” logo is facing you.
      • Remove six 3 mm screws along the perimeter of the back panel using a T5 Torx screwdriver.
      Ask FixBot
    2. Dell XPS 14 RAM Replacement: step 2, image 1 of 3 Dell XPS 14 RAM Replacement: step 2, image 2 of 3 Dell XPS 14 RAM Replacement: step 2, image 3 of 3
      • Use an opening tool to pry up the metal plate.
      • Remove the two 6 mm screws under the silver flap using a Phillips #0 screwdriver.
      Ask FixBot
    3. Dell XPS 14 RAM Replacement: step 3, image 1 of 2 Dell XPS 14 RAM Replacement: step 3, image 2 of 2
      • Use an opening tool to pop out the back panel.
      • Once unhinged, the panel will open away from you.
      • The back panel will still be attached by a ribbon cable. Be cautious when opening the panel to ensure the ribbon stays intact.
      Ask FixBot
    4. Dell XPS 14 RAM Replacement: step 4, image 1 of 3 Dell XPS 14 RAM Replacement: step 4, image 2 of 3 Dell XPS 14 RAM Replacement: step 4, image 3 of 3
      • Flip over the back panel so that the interior of the panel is facing up.
      • Remove three 2 mm screws that are connected to the vendor GCE disk on the bottom left corner of the back panel using a Phillips #0 screwdriver.
      • Remove the black plastic cover that holds the disk in place.
      • Remove the back panel.
      • The GCE disk should still be connected to the computer via a purple ribbon cable.
      Ask FixBot
    1. Dell XPS 14 RAM Replacement, Speaker: step 5, image 1 of 2 Dell XPS 14 RAM Replacement, Speaker: step 5, image 2 of 2
      • Remove four 2 mm screws that are connected to the speaker using a Phillips #0 screwdriver.
      Ask FixBot
    2. Dell XPS 14 RAM Replacement: step 6, image 1 of 2 Dell XPS 14 RAM Replacement: step 6, image 2 of 2
      • Remove the speaker from its original location so the wire connector is visible.
      • Unplug the red and white cable plug by pulling out the white end tag.
      • The speaker is now fully removed.
      Ask FixBot
    1. Dell XPS 14 RAM Replacement, Battery: step 7, image 1 of 1
      • Make sure to ground yourself before removing the battery.
      • Remove the four 6 mm screws from the sides of the battery using a T5 Torx screwdriver.
      • Remove the two 3 mm screws from the top of the battery using a Phillips #0 screwdriver.
      Ask FixBot
    2. Dell XPS 14 RAM Replacement: step 8, image 1 of 3 Dell XPS 14 RAM Replacement: step 8, image 2 of 3 Dell XPS 14 RAM Replacement: step 8, image 3 of 3
      • Detach the battery connector from the motherboard using two thumbs to pop it out.
      • Remove the battery from the laptop.
      Ask FixBot
    1. Dell XPS 14 RAM Replacement, RAM: step 9, image 1 of 3 Dell XPS 14 RAM Replacement, RAM: step 9, image 2 of 3 Dell XPS 14 RAM Replacement, RAM: step 9, image 3 of 3
      • Remove any electrical tape that may be covering or overlapping the RAM cartridge.
      • Push the two metal latches on either side of the RAM outward.
      • The cartridge will pop out of the laptop.
      Ask FixBot
    2. Dell XPS 14 RAM Replacement: step 10, image 1 of 2 Dell XPS 14 RAM Replacement: step 10, image 2 of 2
      • Slide the RAM cartridge out of its slot.
      Ask FixBot
Author
with
Gabriella Monico
457 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 89
All Time: 992
