Dell XPS 14 L401X Mini Card Replacement
    1. Dell XPS 14 L401X Mini Card Replacement, Battery: step 1, image 1 of 2 Dell XPS 14 L401X Mini Card Replacement, Battery: step 1, image 2 of 2
      • Make sure that the laptop is shut off before attempting to remove any components from the device.
      • The laptop in this example did not have a battery equipped.
      • Locate the spring latch on the bottom of the device that will unlatch the battery.
      • Hold the spring latch in the open position and pull the battery out of its recess.
      Ask FixBot
    1. Dell XPS 14 L401X Mini Card Replacement, Mini Card: step 2, image 1 of 3 Dell XPS 14 L401X Mini Card Replacement, Mini Card: step 2, image 2 of 3 Dell XPS 14 L401X Mini Card Replacement, Mini Card: step 2, image 3 of 3
      • Locate the mini card access panel marked with a radio tower emblem on the bottom of the laptop near the battery bay.
      • Use a JIS 1 screwdriver to loosen the captive screw securing the panel to the device.
      • The captive screw will not come off of the panel.
      • Carefully remove the panel by prying it upwards, unlocking it from the tabs that are securing it in place.
      Ask FixBot
    2. Dell XPS 14 L401X Mini Card Replacement: step 3, image 1 of 3 Dell XPS 14 L401X Mini Card Replacement: step 3, image 2 of 3 Dell XPS 14 L401X Mini Card Replacement: step 3, image 3 of 3
      • Disconnect the two wires on the mini card by carefully plucking them upwards by the metal contact points at the terminals.
      • Do not pluck the contacts off of the terminals by pulling on the wires, this can damage the cables.
      • Remove (1) 2mm screw from the bottom left corner of the mini card with a JIS 1 screwdriver.
      Ask FixBot
    3. Dell XPS 14 L401X Mini Card Replacement: step 4, image 1 of 2 Dell XPS 14 L401X Mini Card Replacement: step 4, image 2 of 2
      • Remove the mini card as it flips upward.
      Ask FixBot
Mark
655 Reputation
6 Guides authored
UMass Dartmouth, Team S4-G3, Julie Fall 2017 Member of UMass Dartmouth, Team S4-G3, Julie Fall 2017
UMASSD-JULIE-F17S4G3
3 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 23
Past 30 Days: 102
All Time: 838
