Introduction
Go to step 1 ↓If your keyboard stops functioning properly, you may want to replace the keyboard of your device.
Locate the spring latch on the bottom of the device that will unlatch the battery.
Hold the spring latch in the open position and pull the battery out of its recess.
Use a JIS 1 screwdriver to loosen the (2) captive screws from the panel.
Pull the panel upwards and towards the battery to remove.
Put the panel to the side, exposing the RAM.
Locate and remove (1) 8.5mm JIS 1 screw at the top left corner of the RAM bay.
Use a JIS 1 screwdriver to remove (2) 2.5mm screws located on the right side of the RAM bay.
Locate the mini card access panel marked with a radio tower emblem on the bottom of the laptop near the battery bay.
Use a JIS 1 screwdriver to loosen the captive screw securing the panel to the device.
Carefully remove the panel by prying it upwards, unlocking it from the tabs that are securing it in place.
Remove two 4.5mm screws with JIS 1 screwdriver marked by the letter "K" in the optical drive bay.
Use a JIS 1 screwdriver to remove (2) 2.5mm screws located near the top of the keyboard.
