Dell XPS 14 L401X Hard Drive Replacement
    1. Dell XPS 14 L401X Hard Drive Replacement, Battery: step 1, image 1 of 2 Dell XPS 14 L401X Hard Drive Replacement, Battery: step 1, image 2 of 2
      • Make sure that the laptop is shut off before attempting to remove any components from the device.
      • The laptop in this example did not have a battery equipped.
      • Locate the spring latch on the bottom of the device that will unlatch the battery.
      • Hold the spring latch in the open position and pull the battery out of its recess.
      Ask FixBot
    1. Dell XPS 14 L401X Hard Drive Replacement, RAM: step 2, image 1 of 3 Dell XPS 14 L401X Hard Drive Replacement, RAM: step 2, image 2 of 3 Dell XPS 14 L401X Hard Drive Replacement, RAM: step 2, image 3 of 3
      • Use a JIS 1 screwdriver to loosen the (2) captive screws from the panel.
      • The captive screws will not come off of the panel.
      • Pull the panel upwards and towards the battery to remove.
      • Put the panel to the side, exposing the RAM.
      Ask FixBot
    2. Dell XPS 14 L401X Hard Drive Replacement: step 3, image 1 of 2 Dell XPS 14 L401X Hard Drive Replacement: step 3, image 2 of 2
      • The RAM is held by two spring clips. Pull at the two spring clips and the RAM will move upwards.
      • Keep your fingers on the edge of the chip.
      • Only handle the RAM by the sides! Do not touch the circuits or the terminals to avoid contamination!
      Ask FixBot
    1. Dell XPS 14 L401X Hard Drive Replacement, Hard Drive: step 4, image 1 of 2 Dell XPS 14 L401X Hard Drive Replacement, Hard Drive: step 4, image 2 of 2
      • Use a JIS 1 screwdriver to remove (2) 2.5mm screws located on the right side of the RAM bay.
      Ask FixBot
    2. Dell XPS 14 L401X Hard Drive Replacement: step 5, image 1 of 2 Dell XPS 14 L401X Hard Drive Replacement: step 5, image 2 of 2
      • Push the hard drive to the right with a spudger to unseat it from its socket while pulling out the hard drive with your other hand.
      Ask FixBot
    3. Dell XPS 14 L401X Hard Drive Replacement: step 6, image 1 of 3 Dell XPS 14 L401X Hard Drive Replacement: step 6, image 2 of 3 Dell XPS 14 L401X Hard Drive Replacement: step 6, image 3 of 3
      • Use a JIS 1 screwdriver to remove (1) 2.5mm screw attaching the plastic cosmetic cover to the hard drive.
      • Detach the plastic cosmetic cover from the hard drive.
      • This cosmetic cover will be transferred to the new hard drive.
      Ask FixBot
Nicole Johnson
443 Reputation
4 Guides authored
UMass Dartmouth, Team S4-G3, Julie Fall 2017 Member of UMass Dartmouth, Team S4-G3, Julie Fall 2017
UMASSD-JULIE-F17S4G3
3 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 10
Past 30 Days: 38
All Time: 1,797
